Front drive mandrel
Front drive mandrel Empty Front drive mandrel
Post  dirt_worker August 19th 2013, 9:20 am
Ok fellas i need dome help here.
I'm installing a vacuum pump and an alternator on my 557. I'm using a motor plate and after looking at a lot of brands/styles I'm not sure whos to use. I have the ford racing balancer w the stepped front. Whos drive would you guys recommend?
dirt_worker
dirt_worker
Front drive mandrel Empty Re: Front drive mandrel
Post  dirt_worker August 25th 2013, 8:38 pm
Bump for some help.
dirt_worker
dirt_worker
Front drive mandrel Empty drive mandrel
Post  460pulling August 25th 2013, 9:00 pm
The moroso is suppose to fit the stock balancer . I bought one but it is at Jet Boat Bobs. Its not together enough to test it yet. I called moroso before I bought it and they said they mocked it up from a ford.
460pulling
Post  Barney August 25th 2013, 10:10 pm
Peterson
Barney
Barney
Post  Larry T August 26th 2013, 2:24 am
if I remember correct the ford racing balancer has both ford and gm bolt patterns.ford has 4 bolt holes gm has 3 bolt holes moroso makes both.i used the gm pattern because it was available when I ordered.it comes with various spacers etc to put the pulley were you want it.you may have to put a spacer behind the pump to get the spacing exact.
Last edited by Larry T on August 26th 2013, 3:39 pm; edited 2 times in total (Reason for editing : you are correct i cant remember)
Larry T
Larry T
Post  69F100 August 26th 2013, 12:06 pm
Larry I believe you got the bolt pattern backwards ford is 4 bolt and chevy 3 bolts or the one I have messed with. The early model fords had 3 bolts but that was way back on some 289s and 260s I think been along time like back in my teens when I mess with a couple of them.
