cam pin broke.....
racinghabbit
cam pin broke..... Empty cam pin broke.....
Post  racinghabbit August 19th 2013, 2:12 pm
I had a cam pin snap at 6000 rpm's the other day.. i tore down the motor and all of the valves are bent and all the pushrods are bent a little bit... i have good h-beam rods in it and i was wondering if I should worry about the rod bearings ?
racinghabbit
racinghabbit
cam pin broke..... Empty Re: cam pin broke.....
Post  schmitty August 19th 2013, 2:24 pm
If it's that far apart, a check of the bearings would not take much effort. It would be very comforting to know the exact condition too.
Post  cool40 August 19th 2013, 5:48 pm
I had that problem on a sbf before.i almost fixed the topend but went ahead and pulled the pan.i found a piston skirt but no bad bearings or bent rods. Surprised
Post  Lem Evans August 19th 2013, 5:50 pm
cool40 wrote:I had that problem on a sbf before.i almost fixed the topend but went ahead and pulled the pan.i found a piston skirt but no bad bearings or bent rods. Surprised
Good point....it'd be more like that 'it' would punish a skirt than a rod bearing.
Post  Jeff Jackson August 19th 2013, 7:24 pm
Always double pin the cam.
Jeff Jackson
Post  Dave C. August 19th 2013, 8:45 pm
yep
Dave C.
Post  Lem Evans August 19th 2013, 8:51 pm
Flat tappet or roller? Spring pressure?
Post  dfree383 August 20th 2013, 12:45 pm
And alway use lock tight, a Proper length bolt and bigg ass washer and make sure the snout of the cam isn't sticking out preventing the timing gear from tightening.
Post  IDT-572 August 21st 2013, 11:16 pm
dfree383 wrote:And alway use lock tight, a Proper length bolt and bigg ass washer and make sure the snout of the cam isn't sticking out preventing the timing gear from tightening.
DING DING WINNER...............cheers cheers
Post  racinghabbit August 22nd 2013, 12:13 pm
roller cam with about 700 pressure open..
I did check the pistons and they look fine. didn't pull any rod bolts...
starting it tomorrow... see what happenes... and
It is double pinned now.....
racinghabbit
racinghabbit
Post  IDT-572 August 22nd 2013, 12:27 pm
racinghabbit wrote:roller cam with about 700 pressure open..
Cool
Post  racinghabbit August 27th 2013, 9:19 am
Motor is running perfect... raced on it, and took a third place....
racinghabbit
racinghabbit
