Need some help getting down the track
Dave C.
yellowhorse7
airford1
Heavy 72 Ranchero 3820 with driver.
Stock front end w/90/10s no sway bar
Southside lower bars
air bags
adjustable rear sway bar
QA1 rear shocks 50/50
M/T #3055 10.2 x 28 x 15 slicks
545 c.i. 11.2 to 1 comp
726/726 lift solid roller cam
1050 Dominator on Victor manifold,
Early Blue Thunder heads 80 cc SCJ exhaust port
MSD7al
4:88 gears
C6 foot brake w/3800 EDGE convetor.
Guys I'm new to this and the car goes 11.1@119 in a 1/4 with 4.30 gears. I'm running at the only open track which is 1/8 mile and the car pulls to the left and will unload the tires mid track . Heres a link to some passes. Open to suggestions and Humor. I am looking at the alignment next.
This is the link https://youtu.be/Rx2MEosG6kQ
air bags
MSD7al
4:88 gears
airford1- Posts : 192
Re: Need some help getting down the track
what are the 60's?
yellowhorse7- Posts : 1382
1.64 to 1.58 with 4:88 gear and 1.68 to 1.74 with 4.30 gears
Come on you guys I know its a slow car, I still need help.
Was the track prepped at all? Looked like you were spinning quite a bit?
Dave C.- Posts : 1268
leafspring deal?
No prep I dont think Irwindale can really afford it.Dave C. wrote:Was the track prepped at all? Looked like you were spinning quite a bit?
Coil springs ford stock four link with SSM lower bars and anti roll barrichter69 wrote:leafspring deal?
You're probably not the only one having trouble getting down that track. !
need some pimp juice lol
OK whats pimp juice.......richter69 wrote:need some pimp juice lol
Hard to tell without better video, (sun glare & camera could be a little closer to the car, or zoomed in a little more) but it kinda looks to me like the rear suspension is kinda stiff, or maybe something is in a bind. The rear suspension doesn't really seem to do anything at the hit (separate or squat). It just kinda bounces/oscillates up-down a number of short cycles (either on the rear springs or the sidewalls).
I don't know much about the later year rear coil spring Rancheros, since they are a "truck" do they have a real stiff factory rear coil spring? And are you using a bunch of pressure in the air bags?
Since it's a factory 4-link you might try posting a pic of your rear suspension layout, it might help the factory Fox Body suspension guys offer up some suggestions.
And of course as mentioned earlier it could all just be crap track prep.
DILLIGASDAVE- Posts : 2262
Pimp Juice. Can you still get it?
Mike R- Posts : 1381
Mike R wrote:Pimp Juice. Can you still get it?
I can get all I want, delivered lol.
Sure OKC home of the street outlaws. But what about the rest of us?
ranchero
adjust sway bar, You're putting too much pressure on right side ,which makes car pull left
v-twin- Posts : 52
v-twin wrote:adjust sway bar, You're putting too much pressure on right side ,which makes car pull left
hey v-twin hows your car coming along! anything new done to the engine? talk to you later!
nitrous.f- Posts : 294
New starting line video, I know it's dark and had to see much, but it doing much better.
Thanks for the help.
https://www.youtube.com/watch?v=ZsCgM1TO8CE
Sorry i cant help with the setup but thats a sweet ass ride!!
Bob
Bob
mustang68mustangs1- Posts : 169
It's gettin down the track pretty good now. When Dave Dillagasket said it doesnt do much , just like oscillates, that made me soften the rear and add more weight to the back. Sway bar adjustment, lower air to 11 psi in the slicks and also found some alignment problems in the front. Thanks guys.
airford1 wrote:..................and also found some alignment problems in the front........
Proper front end alignment & geometry can at times go a long way to solving any number of annoying little gremlins thought to be in other areas of the car's suspension.
» Am i on the right track?
» I'm off to the track.
» M.A.D. fer sale
» Running at a Tight Track
» ORSCA IN MMP NOV 6- NOV 8
» M.A.D. fer sale
