air pump speed
air pump speed Empty air pump speed
Post  ironbark August 29th 2013, 6:28 am
at what percentage do you run a race vac pump at, I was told 66 percent is this about standard.
ironbark
air pump speed Empty Re: air pump speed
Post  Wheelie58 August 29th 2013, 8:02 am
It really depends on the pump that is chosen and the application. 66 percent is probably not too far off as a general spec. There are 5 or six different pump manufacturers out there and some if those have 4 different models and sizes, requiring different ratios.
The 22642 Moroso 4 vane enhanced pump is recommended to start at 50 percent, but after talking with their tech dept., I have one of those running at 70 percent.
What I learned was...the faster you spin it, the sooner that the pump will require maintenance.
I hope this helps.
Keith
Wheelie58
Wheelie58
Post  ironbark August 29th 2013, 4:59 pm
mine is new and is MOR22843, large 4 vane.
ironbark
Post  Lem Evans August 29th 2013, 5:24 pm
That's a bad azz pump.
Post  Wheelie58 August 30th 2013, 9:00 am
ironbark wrote:mine is new and is MOR22843, large 4 vane.
I haven't installed one if those yet, but the specs look great. I notice that the option list offers an 18t crank pulley, so I will assume that they intend it to start out at 50%.
A nice big pump like that may not need to spin any faster.
I like the dual feed inlet feature. Cool pump for sure!
Keith
Wheelie58
Wheelie58
Post  ironbark August 30th 2013, 9:53 am
thanks for the input, we will try the 18, 24, and 26 if needed.
will keep you updated.
ironbark
