Need ASAP
Need ASAP Empty Need ASAP
Post  whitefield September 21st 2013, 4:52 pm
I need a c4 trans with bell housing flex plate ( flywheel ) and torque converter for a 170 cid 6cyl mustang 66 up . Thanks Whitey
whitefield
whitefield
Need ASAP Empty Re: Need ASAP
Post  waypastcrazy September 21st 2013, 10:28 pm
Do you need the one where convertor bolts to an x shaped flex and starter ring is on the convertor.
or the one where starter ring is on the flexplate?I have convertor with ring on The tc also have the bell. Not sure when they made the change.
waypastcrazy
waypastcrazy
Post  richter69 September 21st 2013, 11:05 pm
i tossed a bell and converter last month
Post  whitefield September 22nd 2013, 12:15 am
waypastcrazy wrote:Do you need the one where convertor bolts to an x shaped flex and starter ring is on the convertor.
Not sure ! I am doing a 3spd on the column to a automatic in a 66 bronco that has a 170 cid 6cyl mustang engine in it.Tthanks Whitey
whitefield
whitefield
Post  waypastcrazy September 22nd 2013, 2:24 am
This came out of a 65 mustang engine was a 68 model tho
Was a running car that had been rolled sold the engine still have trans and tc
no nothing about it but you r welcome to it as I have no need for it.Lmk
waypastcrazy
waypastcrazy
Post  waypastcrazy September 22nd 2013, 3:33 am
It is a pan fill style bell.
Need ASAP Th_20130922_013033
Need ASAP Th_20130922_013017
Need ASAP Th_20130922_013006
waypastcrazy
waypastcrazy
Post  whitefield September 22nd 2013, 4:12 pm
waypastcrazy wrote:It is a pan fill style bell.
Send me a pm with your address and number and a good time to call you . Thanks Whitey
whitefield
whitefield
Post  waypastcrazy September 25th 2013, 12:19 pm
Pm sent
but may not have sent
waypastcrazy
waypastcrazy
Post  whitefield September 28th 2013, 6:53 pm
waypastcrazy wrote:Pm sent
 I got your pm thanks I will be calling you this week. Thanks Whitey
whitefield
whitefield
Post  whitefield November 9th 2013, 8:53 pm
Thanks Bud , I will be checking on the push rods for you.Cool
whitefield
whitefield
