Need ASAP
+15
D. Sea
crittersf1
racnrick
Diggindeeper
Larry T
whitefield
DanH
Dave C.
19 posters
Page 1 of 2
Page 1 of 2 • 1, 2
Need ASAP
Building a balanced and blueprinted 466 .. Need a full racin cam and some mushroom lifters. Also need some Purple Hornie mufflers or a pair of reversed Smittys. Need some air shocks and slapper bars for ultimate traction. Will also need a short log chain to hold the motor in since I'll be running DX 260 fuel.. Could also use a flex fan since summer is getting closer. As you can tell this will be a race only deal so I'll be runnin wrinkle walled slicks. .. Thanks
Dave C.- Posts : 1268
Re: Need ASAP
pm sent....
Re: Need ASAP
you want mushroom lifters, I'll see if any 292 lifters are floating around here.Dave C. wrote:Building a balanced and blueprinted 466 .. Need a full racin cam and some mushroom lifters. Also need some Purple Hornie mufflers or a pair of reversed Smittys. Need some air shocks and slapper bars for ultimate traction. Will also need a short log chain to hold the motor in since I'll be running DX 260 fuel.. Could also use a flex fan since summer is getting closer. As you can tell this will be a race only deal so I'll be runnin wrinkle walled slicks. .. Thanks
DanH- Posts : 1081
Re: Need ASAP
All I've got is a 3/4 race cam, but its paired with some pop up pistons.
Curt- Posts : 2790
Re: Need ASAP
I have a Jay Allen double thumper cam with spread bore lifters !
![Razz](https://2img.net/i/fa/i/smiles/icon_razz.gif)
![lol!](https://2img.net/i/fa/i/smiles/lol.gif)
whitefield- Posts : 2244
Re: Need ASAP
^^^^^ junk
Re: Need ASAP
richter69 wrote:^^^^^ junk
You trying to knock my sale !
Re: Need ASAP
just helpin out my buddy Dave.
Re: Need ASAP
richter69 wrote:just helpin out my buddy Dave.
I do have a Albert Clark Hyd slider Big Balls cam that work better for him !
Re: Need ASAP
I have a comp roller cam part#34-000-9 it has 25 passes on it springs available also... pm me it your interested.
Larry T- Posts : 1076
Re: Need ASAP
If your serious here is a place . http://www.fbo-uk.com/Composite%20lifters.htm
Re: Need ASAP
I have a flat hyd tappet 3/4 race roller Moon cam w/solid lifters to make it lift faster.It makes every MOTOR its ever been in rev so fast its really scarry. ya wanit
![Smile](https://2img.net/i/fa/i/smiles/icon_smile.gif)
Re: Need ASAP
Still looking for some air shocks .. If i cant find the Smittys i might settle for a pair of Cherry Bombs .. The dumps seam to really like the Smittys as long as the breather lid is flipped .
Re: Need ASAP
Daves already got a real cam.....
Re: Need ASAP
whitefield wrote:I have a Jay Allen double thumper cam with spread bore lifters !![]()
Who is Jay Allen?
(I think I ask that every time I read his name, it always makes me laugh)
Diggindeeper- Posts : 800
Re: Need ASAP
I've got a slightly used 74 timing chain that should work if you advance the cam gear a few teeth and an 850 double pumper with the cool fuel line and the secondaries wired open. Oh , I've also got a Pro Comp dizzy with hardly any slop in it and a racing balancer that only fell off once, red loctite and a tack weld should keep it on. PM me if you're interested
Mike R- Posts : 1381
Re: Need ASAP
I've got a comp cams 292 and a set of ported camel backs off a corvette that should fit if you rework them a little...... Pm me if your interested.
And if it's purple and your still horny.... You better loosen up the grip.
Re: Need ASAP
Almost forgot to mention Willy bars . Poppin a willy looks cool but its hard on the side pipes.
Re: Need ASAP
Dave C. wrote:Almost forgot to mention Willy bars . Poppin a willy looks cool but its hard on the side pipes.
I'm sure you meant "lake pipes".
![Very Happy](https://2img.net/i/fa/i/smiles/icon_biggrin.png)
Curt- Posts : 2790
Re: Need ASAP
Richter69 helping you to pop that willy ?Dave C. wrote:Almost forgot to mention Willy bars . Poppin a willy looks cool but its hard on the side pipes.
DanH- Posts : 1081
Re: Need ASAP
DanH wrote:Richter69 helping you to pop that willy ?Dave C. wrote:Almost forgot to mention Willy bars . Poppin a willy looks cool but its hard on the side pipes.
Is it Richte69 or his cat
![cat](https://2img.net/i/fa/i/smiles/icon_cat.png)
![confused](https://2img.net/i/fa/i/smiles/confused.png)
![silent](https://2img.net/i/fa/i/smiles/icon_silent.png)
I'll have to see if I still have a set of cut-outs for those Lake Pipes, they are the "fancy ones" that have the choke cables to open and close them from the inside!
![Twisted Evil](https://2img.net/i/fa/i/smiles/icon_twisted.gif)
racnrick- Posts : 462
Re: Need ASAP
Be careful if you use the Cherry Bombs (or any other glass packs). I remember my dad telling me that too little back pressure will warp your valves. Just trying to save you some troubles down the road.
By the way, if you put a stack of washers under the rear mounting holes on your slapper bars, it'll jack up the rear of the car so you won't need the air shocks...save that coin for some Split Fire plugs, just be sure to get the twin-core wires too...otherwise the plugs are a waste of money.
maverick- BBF CONTRIBUTOR
Re: Need ASAP
How about some slick 50 for increased hp and fuel mileage!
Re: Need ASAP
I have an Accell Super Coil that will make 50 Horsepower over your stock coil and some foam/chrome triangle breather thingies that always catch fire and adds even MORE horsepower, plus they just look bad ass!!!!
$1000 plus the ride, pm me if interested.
p.s. You need some S/S cragars
D. Sea- Posts : 2768
Page 1 of 2 • 1, 2
Page 1 of 2
