Couple of questions about late 80's Ford Trucks
+8
arless
lghting94
kjett
Galaxie427
12 posters
Couple of questions about late 80's Ford Trucks  Empty Couple of questions about late 80's Ford Trucks
Post  dfree383 September 22nd 2013, 6:19 am
1) What Year did they switch to EFI on the F350 with a 7.5L (460)
2) When did the start using an AOD with the 7.5L (460)
Couple of questions about late 80's Ford Trucks  Empty Re: Couple of questions about late 80's Ford Trucks
Post  Galaxie427 September 22nd 2013, 7:44 am
I originally thought 87 was the first year of ego, but I owned an 88 F350 with a factory carb and a cast iron T18. Not sure about bigger trucks and e4od's, but I also owned an 87 F150 with a C6 in it. Hope this helps!
Galaxie427
Post  Galaxie427 September 22nd 2013, 7:46 am
DAMMIT!!!!!! I hate this autocorrect!! EFI, not ego.
Galaxie427
Post  Lem Evans September 22nd 2013, 10:15 am
dfree383 wrote:1) What Year did they switch to EFI on the F350 with a 7.5L (460)
I used a 1987 to pull the dragboat trailer....it was 4V w/C6. 1988's were EFI....I think.
Wasn't it E4OD behind the 460s?....not AOD.
Post  richter69 September 22nd 2013, 11:40 am
no aod behind the 460
the first e4od was in 89, pretty much all the early e4's were crap
Post  dfree383 September 22nd 2013, 12:44 pm
So it would be a EFI engine with a C6?
Post  kjett September 23rd 2013, 7:57 am
Dave, I know the late 80's trucks (small blocks) had efi motors with the c6. My buddy has an 89 bronco with 351w/c6 combo, so it was probably the same with the 4sexy's...
kjett
kjett
Post  HorsinAround September 23rd 2013, 8:32 am
[quote="dfree383"]1) What Year did they switch to EFI on the F350 with a 7.5L (460)
I was told they started switching to efi on the 460's in late 88. I have seen a model year 88 with a carb, but do not know what the date code was. I do know 89 and 90 were EFI and my 90 had the E4OD behind the 460.
http://www.frontpagefab.com
Post  lghting94 September 23rd 2013, 4:14 pm
I have a buddy with an 88 f-350 crewcab 4x4 that is EFI 460 but it is a 5 speed truck.
lghting94
lghting94
Couple of questions about late 80's Ford Trucks  Empty 460 small pokt eaa,
Post  arless October 2nd 2013, 12:40 am
Galaxie427 wrote:I originally thought 87 was the first year of ego, but I owned an 88 F350 with a factory carb and a cast iron T18.  Not sure about bigger trucks and e4od's, but I also owned an 87 F150 with a C6 in it.  Hope this helps!
My thoughts would be good exhaust. I built up a 450 hp 460. I used the dove heade. performer intake and holley 750, recerved distribiter all in by 2200 rpm 34 degrees total advance. 1 3/4" headers, cam 276x286 advertised 218x228 at.0.50 114 degrees lobe centers over 530 ft lbs torque ar 4000 rpm and 456 hp at 5500rpms mild port work great engine.roller tip rockers 1;7:1 ratio
arless
Post  Dave C. October 2nd 2013, 12:45 am
confused
Dave C.
Post  dfree383 October 2nd 2013, 2:39 am
Its a bot.... Learning auto lingo. Scary Shit that someone is taking the time to make intellegent bots. Think about what they will be used for.
Post  badsnake306 December 18th 2013, 6:50 pm
i own a 88 f350 460/c6 w/ speed density efi
badsnake306
Post  dr's wife racing December 20th 2013, 11:04 am
While we're on the late 80's. Does the 7.3/6.9 diesel share a bell housing pattern with anything?
dr's wife racing
dr's wife racing
Post  HorsinAround December 20th 2013, 11:25 am
Those came from Navistar so the bolt pattern and pin locations are different. I'm not up on the International's to know what transmissions would bolt up to that motor.
Post  61coon December 20th 2013, 11:27 am
dr's wife racing wrote:While we're on the late 80's. Does the 7.3/6.9 diesel share a bell housing pattern with anything?
Nope.They are just for the 7.3/6.9. They are pretty close to a 460 pattern, but the dowel holes are off location and the bolt hole diameters are a little different too.
61coon
61coon
Post  dr's wife racing December 20th 2013, 12:48 pm
Was wondering because there is a nice 86 4x4 exta cab diesel with a 4 speed at the scrap yrd that is for sale at a little over scrap price
dr's wife racing
dr's wife racing
Post  61coon December 20th 2013, 1:57 pm
I like that body style. Put a 7.3 powerstroke in it and find a ZF5 speed to mate up to it. I've never seen one done like that. Would be cool.
61coon
61coon
