Shudder in reverse
Shudder in reverse
What could cause the vehicle to shudder in reverse under a load?
460bronco- Posts : 364
Re: Shudder in reverse
.460bronco wrote:What could cause the vehicle to shudder in reverse under a load?
What trans ? Could be warn low revers clutch seals warpped clutch plates. Modulator or the modulator valve inside the case sticking . Check fluid level and condition as well as do a fluid pressure test.
whitefield- Posts : 2244
I disassembled the trans today and several of the low/ reverse steels had blue spots around them... Guess these were the hot spots causing the shudder.
» NO FIRST OR REVERSE IN MY PG
» C-6 with chatter in reverse
» Low/Reverse Piston
» 800hp c6 build advice
» Reverse valve body/ from 3rd to neu
