BBF C-6 swap w/ motor plate?
How tight of fit is the C-6 w/ stock trans tunnel. Need to have a Trans/flex plate shield? Is there a shield that fits better than others?
wheels123- Posts : 13
Re: BBF C-6 swap w/ motor plate?
What are you putting it in? If it's a fox body, it will be TIGHT with the stock tunnel and will need some love from a BFH
D. Sea- Posts : 2768
swap
It is a fox body. It is an older 10.5 real street car. It had a small block an power glide before and 9"rear. The 3rd member is centered, i did not know if that will help with the fit.
Will the trans/flex plate make it tighter?
Thanks for the help
Thanks for the help
shield
I meant to say, will a trans/flex plate shielsd make it fit tighter?
wheels123 wrote:I meant to say, will a trans/flex plate shielsd make it fit tighter?
It won't help. I've seen some shields that fit the contour of the trans but I haven't used one so I can't say if they are worth the money vs space saved.
» Total Performance motor plate/swap kit?
» Looking for opinions on motor plate / mid plate vs solid mounts / no mid plate on a fox body .
» Mid plate and motor plate for bbf ford-off set
» front motor plate and mid plate
» Motor plate or motor mounts?
