Modifying std header for cj port heads
Modifying std header for cj port heads Empty Modifying std header for cj port heads
Post  tfsbbf466 September 28th 2013, 7:07 pm
I'm trying to open up the bolt holes on my headers so they match the port roof of my TFS heads. I'm trying a dremel tool with carbide bits and it sucks. Holding a drill bit to the side seems to work better. Any suggestions?
tfsbbf466
Modifying std header for cj port heads Empty Re: Modifying std header for cj port heads
Post  Super Snake Steve September 28th 2013, 7:12 pm
Make sure its a high Quality bit or a mounted stone and what ever tool you use is high rmp ie die grinder
Super Snake Steve
Post  rmcomprandy September 28th 2013, 7:53 pm
Put it in a bridgeport and use an end-mill.  Otherwise, use a hand held die grinder with a 5/16" carbide bit.
Post  tfsbbf466 September 28th 2013, 8:09 pm
Ok thanks working on getting a die grinder now. These headers aren't going back on until I make them work right lol. 9s or bust
tfsbbf466
Post  tfsbbf466 September 30th 2013, 5:33 pm
Got the headers all matched up hoping for some positive results from it. It has to help.
tfsbbf466
