EMC 2013 Oakley and Freelander
+22
blown86hallet
Tore
dave d
Darrin Gorham
Oakley Motorsports
Blownshotgun
jeffgfg
bluef100fe
26 posters
Page 1 of 3
Page 1 of 3 • 1, 2, 3
Well we are here, BBF hitting the dyno today.
572" P-51 headed, 4150 carb, with a hydraulic roller and 11.5:1 compression
Its not a HP demon, but damn its got the torque !
Re: EMC 2013 Oakley and Freelander
Good Luck:)
res0rli9- BBF CONTRIBUTOR
Good luck guys...
bluef100fe- Posts : 379
Awesome! Very interested to see how the juice roller does.
Good luck fellas.
windsor- Posts : 1167
The team of Freelander Race Engines/ Oakley Motorsports brought a large displacement 385-series big block Ford measuring 572 cubic inches. Topped with a set of Jon Kaase Racing P51 heads the Ford definitely had the stuff to make big power, and seemed to pull effortlessly through the qualifying runs. Big inches deliver big power and the 870 peak horsepower number posted easily eclipsed the field, as did the 815 lb-ft of torque. The Ford’s size was a handicap however when factored for displacement, resulting in a final score of 2514.6
Read more: http://www.popularhotrodding.com/enginemasters/1309_2013_amsoil_engine_masters_challenge_tuesday_coverage/viewall.html#ixzz2hA1Vqfi1
(that Mod motor is insane...thing probably cost more than my house though)
Wow, and they say hydraulic rollers won't work. That's amazing power!
Can you share some cam specs?
Awesome:D
Blownshotgun- Posts : 51
Thanks guys. fun day! I came home today but Dave stayed to disassemble the engine. Looks like they are going to do a magazine article. Pretty cool!
Oakley Motorsports- BBF VENDOR SPONSOR
Dang Phillip, what did you do to get punished with Freelander? Nice numbers guys.
schmitty- Posts : 4538
815 ft lbs:affraid:
Darrin Gorham- Posts : 180
good luck......
come gents, get us some details!
Hey Freelander your only about 20miles from my home ,how long you going to be in lima
dave d- Posts : 809
John Myrick- BBF CONTRIBUTOR
401 inch mod motor over 2900
How big was the turbo ?
It was electronic fuel infected N/A buy the looks of it. I was afraid that was going to happen when they talked about letting them in. Tons of valve area to bore.
Only one thing to do
with 4 valves and variable cam timing, but damn it sounded good.IDT-572 wrote:401 inch mod motor over 2900
pulls smooth to 7200, but it does have very good parts, you won't get it with the inexpensive lifters.windsor wrote:
Good luck fellas.
Was it the new morel hydros? What kind of cam specs?dfree383 wrote:pulls smooth to 7200, but it does have very good parts, you won't get it with the inexpensive lifters.windsor wrote:
Good luck fellas.
But if you talk to the GM guys they will tell you Mod Motors don't make any power with out Power Adders.IDT-572 wrote:It was electronic fuel infected N/A buy the looks of it. I was afraid that was going to happen when they talked about letting them in. Tons of valve area to bore.
Later Mark.
Mark Miller- Posts : 1959
ok ay now we need some specs !! AND more info !!
Frank Merkl- Posts : 1524
on the 572 !!!
» Dave Freelander
» Hey Freelander
» Freelander....you know this guy?
» Where's Freelander at?
» FREELANDER !!!!!!!!!!!!!!!!!!!!!!!!
» Hey Freelander
Page 1 of 3
