EMC 2013 Oakley and Freelander
+22
blown86hallet
Tore
dave d
Darrin Gorham
Oakley Motorsports
Blownshotgun
jeffgfg
bluef100fe
26 posters
Page 2 of 3
Page 2 of 3 • 1, 2, 3
Re: EMC 2013 Oakley and Freelander
11.4 TO 1 COMPRESSION DIAMOND PISTONS
PORTED P-51 HEADS
CAM 108 WITH .450'S INTAKE AND EXHAUST LOBES
CROWER STAINLESS ROCKERS
MOREL .904 HYD ROLLER LIFTERS
MANLEY 3/8 PUSH RODS AND NEX-TECH SPRINGS
OLIVER RODS
SCAT CRANK
FORD MOTORSPORT BLOCK
JOMAR STUD GIRDLE
I/W DAMPNER
MOROSO STEEL PAN
KAASE PUMP
FORD MOTORSPORTS TIMING CHAIN
PORTED TFS MAFIA INTAKE MANIFOLD
QUICK FUEL CUSTOM 4150 CARB
THANKS FOR THE INTEREST GUYS!
PORTED P-51 HEADS
OLIVER RODS
SCAT CRANK
JOMAR STUD GIRDLE
I/W DAMPNER
MOROSO STEEL PAN
KAASE PUMP
Oakley Motorsports- BBF VENDOR SPONSOR
Very impressive deal you guys put together!
Tore
Tore
Tore- Posts : 865
Good work guys! Thanks for sharing the build Info.
Mod motor. 100mm bore center.
with an 95mm bore, and stock stroke 105mm, that is about 355 cubes. With about 6mm left of bridge between the bores.
max i would give the engine is 96mm with SPRAY bore, that leaves 4mm left of the bridge. (thats cutting it close)
this thing must have one hell of a stroke.!
i figure this is his engine.
100 mm bore centers, 96mm bores (sprayed) , 113.473 stroke with honda rod journals (to clear pan rails) 401 cubes/8 50.125 .
Im not a MOD motor expert, anyone have any other ideas???
Its about time people see what the MOD motor can do!
blown86hallet- Posts : 1012
impressive build guys !!!! thank you for sharing the detailsOakley Motorsports wrote:11.4 TO 1 COMPRESSION DIAMOND PISTONS
PORTED P-51 HEADS
OLIVER RODS
SCAT CRANK
JOMAR STUD GIRDLE
I/W DAMPNER
MOROSO STEEL PAN
KAASE PUMP
word is Jon K. has a MOD motor? is this info correct?
Darrin Gorham- Posts : 180
I believe he has both a Mod and an LS entered.blown86hallet wrote:word is Jon K. has a MOD motor? is this info correct?
BigBlockRanger- Posts : 1267
Someone on YB said Mod and Boss engines.BigBlockRanger wrote:I believe he has both a Mod and an LS entered.blown86hallet wrote:word is Jon K. has a MOD motor? is this info correct?
Later Mark.
Mark Miller- Posts : 1959
Maybe it was BES that had both, but I sure thought I read Kaase did too. Whatever.
Really shocked (in a good way) you guys made that power with a Hyd Roller after the many years I've read on these BBF sites that they suck. Can you share some insight on how this combo will live in a street oriented vehicle and also maybe some durations figures?Oakley Motorsports wrote:11.4 TO 1 COMPRESSION DIAMOND PISTONS
PORTED P-51 HEADS
OLIVER RODS
SCAT CRANK
JOMAR STUD GIRDLE
I/W DAMPNER
MOROSO STEEL PAN
KAASE PUMP
windsor- Posts : 1167
Is that Rob from Canada on your right?
schmitty- Posts : 4538
Dave,you look like the Iatola w/that beard.Too much desert heat?
looks like he laid up in the ac a good bit imo...........
Looks like we won a couple of awards. Pretty cool!
Phillip is right. Rob and I are still here along with Mike, Adney, Randy and David. Went to the banquet tonight and the Freelander/Oakley engine won Horsepower Monster with 870 Hp and Torque Monster with 815 Tq. Congrats:!: Rob is packing around a couple of thousand $ extra as a result.
Ford Mod motors are in the top three spots. Accufab out of California is # 1, Kaase is #2, and Bischloff is #3 as of now. They are in the finals which is tomorrow, and of course that's all subject to change after the top 5 engines are dynoed again.
Uncle Charlie
Uncle Charlie
c.evans- BBF VENDOR SPONSOR
Way to hold the Ford banner high guys. Congrats.
Uncle Charlie, I will try to get the photo's up as soon as I can.
Nice job fellas!
Just wondering why y'all went with such a large cubic inch?
Congrats to the team!
windsor wrote:Nice job fellas!
res0rli9- BBF CONTRIBUTOR
schmitty wrote:Is that Rob from Canada on your right?
Cute couple...Eh
» Dave Freelander
» Hey Freelander
» Freelander....you know this guy?
» Where's Freelander at?
» FREELANDER !!!!!!!!!!!!!!!!!!!!!!!!
» Hey Freelander
Page 2 of 3
