429 crank in a 460?
429 crank in a 460? Empty 429 crank in a 460?
Post  Stevie95 October 12th 2013, 7:17 pm
hey fellas first post here also first engine build and need some info.
I just got my 460 today which turned out to be a 429 out of a 70 Lincoln. when we got it out of the rubble I noticed there was a chunk missing where you bolt in the water pump. Instead I just got another 460 bare block and took off the crank and pistons off of what I thought to be another 460 and took them home. now that I have taken a closer look the pistons say 429 and I am assuming the crank does as well.
I was wondering if the crank from the 429 will fit the 460 I have now and will hold up as well as I here the 460 stock cranks do.
also I've looked around on the sites and read the429 pistons will stick out of the bore please correct me if I am wrong
Thanks.
Stevie95
429 crank in a 460? Empty Re: 429 crank in a 460?
Post  bosshoss October 12th 2013, 7:44 pm
Unless you are talking industrial 429 with the bigger snout any stock 429 crank will fit in any stock 429/460 block
conversly any stock 460 crank will fit in any stock 429/460 block.
There are some 460 cranks that require the hatchet weight to achieve proper balance and in rare instances the newer long bore blocks may need to be relieved/massaged.
All the connecting rods are interchangeable (same length) except for the really weird Nascar 429 shotgun stuff.
The pistons you use have to match the crank.
460 pistons on a 429 crank will fit, motor might even run but it would have very low compression... it would be a dog.
429 pistons with a 460 crank would result in the pistons coming out of the bore by a ton and the engine would not turn over with the heads on.
Keep reading
Lots of good info here.
dkp
bosshoss
bosshoss
Post  69F100 October 12th 2013, 7:47 pm
As long as you use the crank from the 429 you will be good is the 460 block a DIVE if so the 429 crank will work but if it is a D9ab it will take some machine work to make it fit in the d9 block
Post  Stevie95 October 12th 2013, 7:50 pm
what about 429 pistons on a 429 crank in a 460 block? will they still jump out?
Stevie95
Post  Stevie95 October 12th 2013, 7:52 pm
69F100 wrote:As long as you use the crank from the 429 you will be good is the 460 block a DIVE if so the 429 crank will work but if it is a D9ab it will take some machine work to make it fit in the d9 block
its a DIVE
Stevie95
Post  cool40 October 12th 2013, 7:55 pm
429 crank and pistons will work for you.
Post  Stevie95 October 12th 2013, 7:57 pm
one more question and ill be out of your hair guys.
would the engine be considered a 460 or a 429? or just some mutt
Stevie95
Post  schmitty October 12th 2013, 8:13 pm
If it's a 3.85" stroke 460 crank and pistons, it's a 460 cubic inch engine. If it's the 3.59" 429 crank and pistons, it's a 429 cubic inch engine.
Post  Stevie95 October 12th 2013, 8:15 pm
thanks for the help guys.
Stevie95
Post  69F100 October 12th 2013, 9:53 pm
Stevie95 wrote:what about 429 pistons on a 429 crank in a 460 block? will they still jump out?
429 and 460 uses the same block up until 1979
