D0oe-R shaft mount rockers
Can A429 shaft mount rockers (like from T&D) be used on iron scj heads? Anyone done this? Any advice/things to know on geometry, Valve length/ Valve lift?
Looking to build a 4.3" stroker sleeper with serious valvetrain under stock scj valve covers.
Calypso- Posts : 71
Re: D0oe-R shaft mount rockers
There are two different machining and valve train geometries produced with A429 heads ... one is the same and one is not.Calypso wrote:Can A429 shaft mount rockers (like from T&D) be used on iron scj heads? Anyone done this? Any advice/things to know on geometry, Valve length/ Valve lift?
I'm thinking the early a429 is the same as the iron if it goes by the same rule as the stud girdles.
Actually ... the A429 heads produced in the middle runs were different than early and later heads.bbf-falcon wrote:I'm thinking the early a429 is the same as the iron if it goes by the same rule as the stud girdles.
It can be identified with casting number dates or required girdles.
I have a set of the early a429s..whats the casting # of the middle one's? mine mite be them:scratch:rmcomprandy wrote:Actually ... the A429 heads produced in the middle runs were different than early and later heads.bbf-falcon wrote:I'm thinking the early a429 is the same as the iron if it goes by the same rule as the stud girdles.
res0rli9- BBF CONTRIBUTOR
Checked from Jomar catalog. Serials 2000-5000 are different from iron heads.
Thanks for the warning.
Calypso- Posts : 71
» T&D shaft mount torq spec?
» Converting SBF pedestal mount heads to adjustable rockers... Which length rockers to use???
» D0OE-R heads with pedestal type rockers now...Is it easy to change to studs?
» rocker girdle vs. shaft mount
» SHAFT MOUNTED ROCKER ARMS
