compression calculators
Is Diamonds calculator pretty accurate? i was running some number on a 557 and 16.32 seems a little high. But here in colorado i bet its closers to 14.7-15.
Ace
Ace
powerstrokeace- Posts : 1496
Re: compression calculators
Yes, I would think that it is very close. Barometric pressure affects the tune at higher altitude, but I don't think it would change the compression ratio of a piston.
Curt- Posts : 2791
» Can you raise compression by changing rod length with same compression height?
» Engine Horsepower calculators
» how can i tell the compression
» Cam/Compression help on 472
» 545 compression
» 545 compression
