Cam/Compression help on 472
I have C9VE block that is .060 with an uncut deck, so it should be 10.300 or there about. I also have a set of cast .060 Silvolte (#1143) pistons, which show a compression height of 1.760 on the box. The heads I have and want to use, are a set of C8VE's that have a nice port job with good stainless valves at OEM size;
Int 2.08(Ferrea 5000 series) and Ex 1.65 (Comp products valve). The heads have been setup with Comp 924 springs, ARP studs, guideplates and have been milled to a 70cc chamber. The heads were milled to 70cc ,for another project that never materialized.
My worry here, is to much compression for 100% 93 octane fuel. I figuring, even if the heads weren't milled, compression would already be pushing 10.0:1 and with my heads at 70cc, it would be a good bit over 10.0:1 The cam that I'm eyeing is the Lunati 61602 (219/227@.050). Do you guys think this is too far on the edge with compression and smallish cam to be a nice trouble free driver? Car is 1973 Torino with C6 and 2.75:1 gears.
I have the option of using a D1VE block but I would have to have it bored .060, which it doesn't need. This C9VE block cleaned up fine at .060, that is why I would like to use it, but I don't want a finicky engine, due to compression. Thanks in advance!
bbfguy1- Posts : 61
Re: Cam/Compression help on 472
I think while it is apart maybe switch to a cam with some more duration, should be of some help & not too much $$. Is E-85 available in your area? Also not sure of converter you have but with 2.75 gears lugging the engine will not help the situation.
Sheldon G.
Sheldon G.
STR-LGL-70- Posts : 223
10.3:1 compression ratio, yes it will run on 93 octane fuel, long block capable of about 400hp depending on the bolt-ons.
The caveat is the full-size car with its 2.75 axle ratio. I think it will drive fine as a daily driver on 93 octane, however under heavy loads it will probably rattle. You are better off with the C9 block than the undecked D1 block.
Personally I’d run the recipe just as proposed, less so for a customer build.
I think the duration at .050" is fine but, personally I would use a cam with a bit more intake seat duration and tighter separation for helping the detonation resistance somewhat.
Thanks for the input and advice! For grins, I got on the phone with Bullet Cams yesterday and they came up with a custom grind that is below. It's a bit more cam than I would like and will require a mild 2200-2500 torque converter but I was told, it should still make vacuum for brakes/AC and help with resisting detonation. Randy, is this more of the type of cam that you had in mind?
279/287 Adv.
227/235@.050
Int. .530/Ex. .530
LSA. 109
279/287 Adv.
227/235@.050
Int. .530/Ex. .530
LSA. 109
bbfguy1- Posts : 61
bbfguy1 wrote:Thanks for the input and advice! For grins, I got on the phone with Bullet Cams yesterday and they came up with a custom grind that is below. It's a bit more cam than I would like and will require a mild 2200-2500 torque converter but I was told, it should still make vacuum for brakes/AC and help with resisting detonation. Randy, is this more of the type of cam that you had in mind?
279/287 Adv.
227/235@.050
Int. .530/Ex. .530
LSA. 109
Not really but, it will work fine.
279/287 Adv.
227/235@.050
Int. .530/Ex. .530
LSA. 109
You should probably call him and ask him. I did, and he delivered EXACTLY what I was asking for.
The finest in custom engine building for all venues ...!
Selling those Parts & Supplies from companies I use ... 1 (586)909-1591 ... fax 1 (586)771-2930
CUSTOM ground camshafts
Carburetor modifications for specific applications
CNC porting
cletus66- Posts : 865
Thanks all for the advice. I will give Randy a call and discuss with him, his recommendation and let him supply it.
bbfguy1- Posts : 61
» Can you raise compression by changing rod length with same compression height?
» 545 compression
» Compression help !
» compression ?
» how can i tell the compression
» 545 compression
» compression ?
