Compression help !
Compression help ! Empty Compression help !
Post  ctdck April 20th 2017, 9:47 pm
I Have 1986 460 out of a motor home stock bore, crank, rods and pistons, I pulled the d3ve heads off and put c8ve-e heads on. The heads have cobra jet size valves 2.250 intake 1.760 exhaust , they been milled 0.10 thousandths I put stock fel-pro head gaskets on I think there 41 thousands compressed . Just kind of wondering around what my compression might be?
Thanks for any help!!!
ctdck
Compression help ! Empty Re: Compression help !
Post  rmcomprandy April 20th 2017, 10:44 pm
ctdck wrote:I Have 1986 460 out of a motor home stock bore, crank, rods and pistons, I pulled the d3ve heads off and put c8ve-e heads on. The heads have cobra jet size valves 2.250 intake 1.760 exhaust , they been milled 0.10 thousandths I put stock fel-pro head gaskets on I think there 41 thousands compressed . Just kind of wondering around what my compression might be?
Probably around 8 to 1.
Post  Mark Miller April 20th 2017, 11:19 pm
Wouldn't have been around 8 to 1 with the D3VE Heads?
Post  BBFTorino April 21st 2017, 12:34 am
Probably about 9.2:1
Post  dfree383 April 21st 2017, 8:10 am
In the 9-9.5 range depending on head actual CC.
Bet on closer to 9
Post  rmcomprandy April 21st 2017, 10:03 am
I misread -- I was reading D8VE heads like some marine engines had.
"86 motorhome short block = 22 cc oblong dish pistons about .040" down the bore; (about 10 cc).
11.5 cc head gasket
about 76 cc combustion chamber head
942 cc cylinder
The math says about 8.9/1 ...
Compression help ! Empty Thank you
Post  ctdck April 21st 2017, 4:55 pm
Thanks all of you for the help
ctdck
