compression ?
compression ?
the rotating assembly i bought said my compression w zero deck and 58cc chambers would be 13.6 to 1. my heads are a429's that are at 68cc. what would my compression be? im useing a felpro gasket(.041 compressed?). what is zero deck? does that mean the piston is even with the deck at top dead center? thanks
new2460- Posts : 195
Re: compression ?
What's the piston manufacture and part number? What bore and stroke?
Re: compression ?
Just about 12.7:1
bb429power- Posts : 3129
» Can you raise compression by changing rod length with same compression height?
» Compression help !
» how can i tell the compression
» Cam/Compression help on 472
» 545 compression
» 545 compression
