460 advise.
MiamiSC
Page 2 of 3
Page 2 of 3 • 1, 2, 3
Re: 460 advise.
So this straight gas differs from another gas that is leading an alternative lifestyle?dfree383 wrote:E85 only. The metering is different for ethanol vs strait gas.MiamiSC wrote:So if I convert to an e85 carb does it only run e85 after that or I could run race fuel through it?
Once you decide on a fuel and carb, it's always a good idea to just stick with it. Without a hydrometer, you will never know what you have exactly, and catastophic damage will happen.
schmitty- Posts : 4538
Re: 460 advise.
E-85 = 85% ethanol 15% Gas, Gas can be anthing from 100% Gas to 85% Gas and 15% Ethanol depending on where you live.schmitty wrote:So this straight gas differs from another gas that is leading an alternative lifestyle?dfree383 wrote:E85 only. The metering is different for ethanol vs strait gas.MiamiSC wrote:So if I convert to an e85 carb does it only run e85 after that or I could run race fuel through it?
Re: 460 advise.
Yea its 10% ethanol down here. One of my heads is missing aFreeze plug looking thing but its actually smaller than a freeze plug on the engine. Where can I find one?
MiamiSC- Posts : 67
Re: 460 advise.
you mean the plug for the emissions hole on the end of the head?
Re: 460 advise.
measure it and hit the parts store for a steel plug.
Re: 460 advise.
Found out today the previous owner was running 100LL aviation gas with this engine. I started working on the car today and got the engine ready to come out except fuel lines, exhaust and engine mounts.
[img][/img]
[img][/img]
[img][/img]
[img][/img]
MiamiSC- Posts : 67
Re: 460 advise.
You may want to rethink the IRS if your planning to run slicks with this combo.
Re: 460 advise.
There's a few guys running IRS with slicks. I just need to get fat halfshafts.
MiamiSC- Posts : 67
Re: 460 advise.
Thanks! Napa had it. P/N 381-2188 for those who might need it in the future.dfree383 wrote:measure it and hit the parts store for a steel plug.
[img][/img]
[img][/img]
MiamiSC- Posts : 67
Re: 460 advise.
Are ARP head bolts really necessary on this engine?
MiamiSC- Posts : 67
Re: 460 advise.
No.....
Re: 460 advise.
Thanks man, is it safe to reuse the stock bolts or get new ones?
MiamiSC- Posts : 67
Re: 460 advise.
Reuse them if they look good, and threads aren't messed up.
Re: 460 advise.
Ok so I bought a msd blaster 2 high vibration coil. Tomorrow I'm picking up a ford duraspark from auto zone. I also found a Mallory hyfire box, research says it should be just as good as the msd 6al but cheaper, is it?
MiamiSC- Posts : 67
Re: 460 advise.
Ford duraspark will work fine ,but not until it's setup correctly.
Re: 460 advise.
Locking it out?bbf-falcon wrote:Ford duraspark will work fine ,but not until it's setup correctly.
MiamiSC- Posts : 67
Re: 460 advise.
If thats what you prefer. I like recurve and light springs personally unless you want to mess w/timing retard.
Re: 460 advise.
I guess whatever is easier. I found a good link on recurving looks pretty easy.
MiamiSC- Posts : 67
Re: 460 advise.
By government standards, station pump E85 can be anywhere from 62% to 89% ethanol.dfree383 wrote:
E-85 = 85% ethanol 15% Gas, Gas can be anyhing from 100% Gas to 85% Gas and 15% Ethanol depending on where you live.
It will be different almost every time you go to a regular station pump; same as pump gasoline will be slightly different.
Re: 460 advise.
I think I'm going to do 93 octane fuel with about 5 gallons of avgas. I work in the airport, I just have to see if they would sell it to me if I show up with my car.
MiamiSC- Posts : 67
Re: 460 advise.
Show up with a gas can, they are not allowed to pump it into cars.MiamiSC wrote:I think I'm going to do 93 octane fuel with about 5 gallons of avgas. I work in the airport, I just have to see if they would sell it to me if I show up with my car.
it just got serious ;).
Engine and tranny are out. I almost hung myself , the cherry picker would hit garage door and engine wasnt out all the way, almost cracked the door
[img][/img]
[img]
[/img]
[img][/img]
I also just bought the summit ignition box instead of the msd 6al.
[img][/img]
[img]
[/img]
[img][/img]
MiamiSC- Posts : 67
carb
Can you guys please let me know if this is a good carb for my setup?
http://www.racingjunk.com/Carburetors/182017447/1050-2-Circuit-Dominator.html
MiamiSC- Posts : 67
» Proceedure for checking valves clearance?
» 429/460 build advise
» New BBF build advise
» ADVISE ON COMBO
» ENDERLE SETUP ADVISE
» ADVISE ON COMBO
Page 2 of 3
