Ford Motorsports A460 Flow number (stock)
460pulling
powerstrokeace
Guy's I'm looking for the original flow (unported) flow numbers for the Ford Motorsports A460 heads with a 2.30/ 1.88 valves. just trying to compare what we have.
Ace
Ace
powerstrokeace- Posts : 1496
Re: Ford Motorsports A460 Flow number (stock)
Here's some ported numbers.
http://www.users.interport.net/s/r/srweiss/tablehdc.htm#Ford
I think he wants unported numbers.
I flowed a set that were untouched they went about 380 @ .800 lift
I believe that the heads will flow good numbers ported. But I also remember the chamber leaves a little bit to be desired.powerstrokeace wrote:Guy's I'm looking for the original flow (unported) flow numbers for the Ford Motorsports A460 heads with a 2.30/ 1.88 valves. just trying to compare what we have.
Ace
460pulling- Posts : 249
This is the deal. I'm having a debate with my head guy here. He say there been some minor pocket work done bit I think not. These heads wee flowed on his bench In 2002 and intake maxed out at 383 @ .700 and he recorded the same flow at .800? The exh. Was 240. @ .700 and 247@ .800. So I'm just trying to get him to understand that there pretty much stock. The pocket work may have been to I shroud a valve ?
Ace
Ace
Mine had nothing done in the short turn cuz I didnt know what to do at the time.it took a lot just to get them to fit the gasket.they had defiantly never been run.they only went 360.
Get after the short side, it is shaped like a 90 degree turn. Do a small amount at a time and check your results. Flow will come quickly.
I did a set the other day i stepped up to a 2.350 valve and worked on peak flow at .700 lift I got them to 440 cfm
My ported ones are listed on Stans site under dfree383, they have a 45 degree valve job and TI intakes.
DOSE THE TITANIUM IT TAKE FLOW BETTER THAN THE STAINLESS?dfree383 wrote:My ported ones are listed on Stans site under dfree383, they have a 45 degree valve job and TI intakes.
ACE
In some cases yes, but I do not have back to back tests on these heads.
Biggest reason for the Titanium, killing valve weight. Easier to control valve when it weighs 30 grams less.
kim- Posts : 700
looking for this:
G-Code- Posts : 193
If the ti valve is shaped better the flow certainly can be better. If the valve is just a repo of a steel valve it'll just be lighter.powerstrokeace wrote:DOSE THE TITANIUM IT TAKE FLOW BETTER THAN THE STAINLESS?dfree383 wrote:My ported ones are listed on Stans site under dfree383, they have a 45 degree valve job and TI intakes.
ACE
G-Code wrote:
looking for this:
That's the TFS heads. I'm talking the FORD Motorsports heads
Ace
oops.
I'll check a file at the office tomorrow there's a chance I have something from '93-'95
G-Code- Posts : 193
IDT-572 wrote:I flowed a set that were untouched they went about 380 @ .800 lift
That is the story right there.
I am susprised the peak was not at ~ .750"
Almost the same numbers at .750 and .800Lem Evans wrote:IDT-572 wrote:I flowed a set that were untouched they went about 380 @ .800 lift
Here's the deal. I'm sending these heads to someone in KY and he's going to look them over for not a max port deal but a velocity deal since we have no air up here. Also will reflow the heads here as my local guy has never had any A460 heads (Motorsports or TFS) flow more thatn 418/295(18bolt tfs) on his flow bench. I have a 2nd set of FORD MOTORSPORTS heads that have been mill to 67cc chambers and he flowed these after his valve job and the flowed 402/282 (ported by someone). The 2nd set i tried selling a few years back but desided to keep them and put them back on this motor they came from.
Ace
I thought I had a "unported" sheet, but I couldn't find it. These were ported ... more than lightly but not maxed out by any means. date was '99. the 380 numbers that was stated sounds about right.
these head were further "rubbed on" and are now on the 528" pump gas deal I did. 843hp at 6,900
G-Code- Posts : 193
I have a set that are flowing quite well. I am the 4th or 5th owner. And they are around 460 319
» Ford Motorsports A460 heads
» Older Motorsports A460 heads
» Trick Flow A460 360cc heads cnc flow numbers
» A460 part number
» Ford Motor Sport A460 Intake Part # M-9424-a460 125.00 shipped
» A460 part number
