Trick Flow A460 360cc heads cnc flow numbers
crittersf1
CHARLIEB
Trick Flow A460 360cc heads cnc flow numbers  Empty Trick Flow A460 360cc heads cnc flow numbers
Post  CHARLIEB September 8th 2012, 3:23 pm
I was wanting to know do anybody knows the flow numbers of Charlie or Lem A460 360cc heads from Trick Flow
CHARLIEB
CHARLIEB
Trick Flow A460 360cc heads cnc flow numbers  Empty Re: Trick Flow A460 360cc heads cnc flow numbers
Post  crittersf1 September 8th 2012, 3:43 pm
Ask Charlie.
crittersf1
crittersf1
Post  rmcomprandy September 8th 2012, 4:39 pm
CHARLIEB wrote:I was wanting to know do anybody knows the flow numbers of Charlie or Lem A460 360cc heads from Trick Flow
Trick Flow provides the flow numbers of their "out of the box" A460 heads on a spec sheet packaged with the head so, this is no secret and I'm sure if you call them and ask, they could send you one.
Post  schmitty September 8th 2012, 5:46 pm
Most of the A460 stuff that is CNC'd is in the mid 400's on the intake side, but with a little hand rubbing Charlie, Randy, and Phillip Oakley have done much better than that. Peak flow is only part of the equation, and there are plenty of engines out there making rediculous power without having the big top end flow numbers. Cool
Post  crittersf1 September 8th 2012, 6:12 pm
Charlie has my EX514's averaging 448 on the intake side.
crittersf1
crittersf1
Post  powerstrokeace September 8th 2012, 10:26 pm
Lift Intake Exhaust
0.100 80 72
0.200 170 134
0.300 251 182
0.400 325 227
0.500 389 271
0.600 430 312
0.700 455 345
0.800 463 364
* Tests conducted at 28" of water 2.40 valve and 1.88 valve These are not Charlie's but his are really close. You asked for numbers and here's numbers. I'm sending mine to charlie as this company only wanted to work on NEW HEADS only
Ace
powerstrokeace
powerstrokeace
Post  CHARLIEB September 9th 2012, 5:41 pm
Ok Thank You !
CHARLIEB
CHARLIEB
Post  CHARLIEB September 9th 2012, 5:43 pm
Yes I did see the flow numbers on their site. Thanks, Randy
CHARLIEB
CHARLIEB
Post  CHARLIEB September 9th 2012, 5:46 pm
schmitty wrote:Most of the A460 stuff that is CNC'd is in the mid 400's on the intake side, but with a little hand rubbing Charlie, Randy, and Phillip Oakley have done much better than that. Peak flow is only part of the equation, and there are plenty of engines out there making rediculous power without having the big top end flow numbers. Cool
Hey Schmitty, Well I just had want it to know some flow numbers. Thank you for your input on these question I had here.
CHARLIEB
CHARLIEB
Post  CHARLIEB September 9th 2012, 5:48 pm
crittersf1 wrote:Charlie has my EX514's averaging 448 on the intake side.
Oh ok is that the same exhaust pattern as the trick flow's ?
CHARLIEB
CHARLIEB
Post  CHARLIEB September 9th 2012, 5:52 pm
powerstrokeace wrote:Lift Intake Exhaust
0.100 80 72
0.200 170 134
0.300 251 182
0.400 325 227
0.500 389 271
0.600 430 312
0.700 455 345
0.800 463 364
Ace
I saw those same numbers on total engine airflow, seem like some very good numbers and the price is pretty fair for some cnc heads. What You Think?
CHARLIEB
CHARLIEB
Post  schmitty September 9th 2012, 7:21 pm
Summit owns Trick Flow and TEA, so if you are getting these from Summit, they will be CNC'd by TEA. Charlie Evans had TEA do his CNC stuff in the past, not sure if he still does or not after it was purchased by Summit. Cool
Post  mr.horsepower September 9th 2012, 8:16 pm
ex514s have a totally differant layout then the new trickflows, a bbc header will bolt right to the tfs head but not the ex514
mr.horsepower
mr.horsepower
Post  CHARLIEB September 10th 2012, 1:49 am
Thank You, The headers I have are kooks stainless steel for trick flow heads
CHARLIEB
CHARLIEB
Post  CHARLIEB September 10th 2012, 1:54 am
schmitty wrote:Summit owns Trick Flow and TEA, so if you are getting these from Summit, they will be CNC'd by TEA. Charlie Evans had TEA do his CNC stuff in the past, not sure if he still does or not after it was purchased by Summit. Cool
Schmitty, you are so right about summit owning both companies and on the summit site the heads are the same price as the ones at TEA. the trick flow site dont so these heads having that much flow, I feel it would be better getting through Evans or TEA.
CHARLIEB
CHARLIEB
Post  Oakley Motorsports September 10th 2012, 2:38 pm
There are a couple of programs and a couple of combustion chambers and then a selection of valve jobs. I would recommend you give Lem a shout he can sale them to you as cheap as anybody. He can also work with you on getting the correct valve size and valve job for your application. We have a ton of Testing with these heads and it is real easy to go from the crap house to the penthouse and also the other way.
Oakley Motorsports
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  bruno September 10th 2012, 11:12 pm
penthouse baby study cheers
http://WWW.CKRME.COM
