A460 flow numbers
tconnection
A460 flow numbers
Is 485in and 354ex flow in a set a460 heads?
tconnection- Posts : 866
Re: A460 flow numbers
are you asking if thats good? Or are you asking if its possible?
Sorry bout that, i didnt use the ? mark. Possible, is it possible?
tconnection wrote:Sorry bout that, i didnt use the ? mark. Possible, is it possible?
Exhaust numbers look a little bit high, but I have seen those intake numbers and even better in the past.
http://www.besracing.com/cylinder-head-and-intake-packages/cylinder-heads/bes-tfs-a460-heads
nitro717- Posts : 92
my ex flowed 361. I would have to have experience with that particular bench to say how good or bad it is
bore flowed? Pipe? Valve size? Stuff like that. Id say its more than possible, but without havingba comparison flowed on that particular bench they're just numbers.
dfree383 wrote:tconnection wrote:Sorry bout that, i didnt use the ? mark. Possible, is it possible?
The exh. #s can vary 35-40 cfm if a pipe and a valve with a steep underhead angle is used vs the standard s.s. valve that comes with the tfs assemblied heads. Also, using a 50*-55* valve job will be good for some #s .
Bottom line is that a well executed custom ti valve + a pipe will make things happen.
I know that a good bit of peps say that numbers are just numbers. I was just wondering what those kind of numbers on a 605ci would bring to the table, 15:1, mid 800 lift, 114ls?
my eliminator heads flow 500/350 w/o a pipe. https://www.429-460.com/t11058-eliminator-605
» Trick Flow A460 360cc heads cnc flow numbers
» a460 flow numbers
» A460 Flow Numbers?
» A460 head flow numbers
» So this isn't good is it? A460 Head Flow Numbers
» a460 flow numbers
