Whats the best route to go for dual carbs?
bronco911
Running thru the Holley sizing calculator I get the 1250 is the largest made, so I should consider dual carbs screen. Is this where some of my power may be lost?
What is the best way to tackle this issue? 2 850's?
593 CI w/max 7500 rpm
bronco911- Posts : 103
Re: Whats the best route to go for dual carbs?
Thanks Lem. Just went and looked at them.Lem Evans wrote:QFT has 1450 QFX series carbs.
How do you think they would hold up in the off-road/sand in everything environment? Have you heard any bad about them?
Those are great carbs. Just run a good filter.
maverick- BBF CONTRIBUTOR
Will this bolt right on in place of my 1250 Holley? Reading the specs can't flat out find the answer, a little vagueLem Evans wrote:QFT has 1450 QFX series carbs.
yes, unless you have a 4 hole spacer under the 1250 to match.
I've been using a QFX 1450 on my mud drag 604" C head combo since it was built, and can say it is the real deal, and you wouldn't be dissappointed if you went that route.
schmitty- Posts : 4538
Ignore all those questions I just asked Scmitty ( except the important one)schmitty wrote:I've been using a QFX 1450 on my mud drag 604" C head combo since it was built, and can say it is the real deal, and you wouldn't be dissappointed if you went that route.
Thanks!
I was gonna say ...You should ask Schmitty here ... he has had one on his mud truck for the past 2 1/2 years but, he has already answered.bronco911 wrote:Thanks Lem. Just went and looked at them.Lem Evans wrote:QFT has 1450 QFX series carbs.
For the displacement and RPM that 1400 cfm is even small Two 1250's would work well.
kim- Posts : 700
What is the intended use of the motor?
fatal addiction- Posts : 433
Trying to go 300' in 4.4ish seconds in a 4,200 lb Bronco. In sand. With up to 8 passengers. No bottle, NA gas.fatal addiction wrote:What is the intended use of the motor?
Going from previous bests of 4.80's to 4.40's, with no wieght changes? Gonna take more than a tunnel ram I'd bet. Time for the fast gas, or push air in it. I went from 5.80's to 5.1's with 160hp/100# NA power gain. But that was slow, easy to improve. The faster you go, the more work it takes to gain. I wonder what sort of power you'd be needing, 1100-1300? Similar vehicles (weight wise) seem to need that sort of power for what your wanting. Maybe those A-heads are something for you to think about.bronco911 wrote:Trying to go 300' in 4.4ish seconds in a 4,200 lb Bronco. In sand. With up to 8 passengers. No bottle, NA gas.fatal addiction wrote:What is the intended use of the motor?
J.Toney- Posts : 398
» Dual or single carb setup
» Holley Dual Quad Carbs
» Edelbrock Performer RPM #75854 351W Dual Quad Intake Polished
» How to route radiator hose after AC bracket install
» 1995 429 into a 1984 truck
