How to route radiator hose after AC bracket install
I bought the CVF Racing billet AC bracket. After installing it im having trouble figuring out how to route the upper radiator hose.
I was wondering if anyone has also bought this bracket and how they went about routing there upper radiator hose?
***i have purchased an aftermarket radiator (3 row) upper hose outlet is on the passenger side, same as AC***
http://www.cvfracing.com/Ford-Big-Block-AC-Compressor-Bracket-p/460-acbrkt.htm link to bracket
Andre.servin- Posts : 49
Re: How to route radiator hose after AC bracket install
Did you contact them about this?
I contacted them once to ask about hood clearance. Their response was "we don't have a fleet of vehicles to test this on". Well I didn't expect them to have a fleet but they should have tested the setup in real world situations in common Fords that would have a big block.
Just makes you wonder how much thought went into the setup.
Also have you tried a truck thermostat housing? Its angled up more compared to the car versions. That and a flex hose might get you around the AC pump
SLord82- Posts : 145
What I ended up doing was slicing 2 hoses and making them work with connectors. Funny I didn't even think of good clearance! I think I may be okay only because I fabricated my own fiberglass hood, so there is no underhood support braces like a steel hood.
It's definitely something a guy would not think about till it was in the car and you get that wtf moment.
jasonf- BBF CONTRIBUTOR
I got lucky and it cleared! But yes your 100% correct
» 4an hose ends, tees, and hose
» 1995 429 into a 1984 truck
» Route 66 nats
» vacum advance hose connection
» Whats the best route to go for dual carbs?
» Route 66 nats
