Port nozzle location
On a single 4 open plenum race manifold, is there a secret location in the port for the nitrous nozzle?
The Trick Flow A460 manifold has nice cast bosses about 1" from the gasket flange. Is that a good place or should a separate boss be welded higher on the port leg? This is referring to an annular type nozzle.
Any input will be great.
Thanks,
Keith
Thanks,
Keith
Re: Port nozzle location
Wish I could help you but I don't know anything about FI ... I think if I decide to run FI/ nitrous , I would prefer the port injection...
Dave C.- Posts : 1268
Oh...I was referring to nitrous nozzles for a buddy's project. It will have a gas carb.
Keith
Keith
itll hit harder the higher up its in the runner, but that said most single stage direct ports have the nozzels close to the runner exit.......I wouldnt fuss to much over it. Bosses should be plenty thick enough where the weld in bungs come into play is when the runner wall is real thin and the annulars need a fairly tall area for the nozzel tomthread into as the nozzel tip is not hanging into the port. 90 degree nozzels are a diff story.
Thanks for the input. I was thinking that the Trick Flow boss near the flange would be fine....but just had to ask.
Keith
Keith
Low like your talking is fine. We normally mill off that big chunk and add our bung in it's place. That factory cast area is very thick.. SJWheelie58 wrote:Thanks for the input. I was thinking that the Trick Flow boss near the flange would be fine....but just had to ask.
Keith
Steve Johnson
Induction Solutions
16121 Flight Path Dr.
Brooksville, Fl. 34604
Shop 352-593-5900
Cell 815-341-8853
www.InductionSolutions.com
Steve,Induction-Solutions wrote:Low like your talking is fine. We normally mill off that big chunk and add our bung in it's place. That factory cast area is very thick.. SJWheelie58 wrote:Thanks for the input. I was thinking that the Trick Flow boss near the flange would be fine....but just had to ask.
Keith
Thank you!
Keith
Here's an example of what we do.. First mill off and blend casting
Then we bore holes..
Place bungs and weld...
Then finish and blend back to port...
All done..
Thanks, SJ
All done..
Thanks, SJ
Steve Johnson
Induction Solutions
Shop 352-593-5900
Cell 815-341-8853
My junky ass intake should be there.....
Nice pics and detail!
I don't always do spray...but when I do, I prefer Induction Solutions!
( from the most interesting Hose Man in the world commercials)
Thanks,
Keith
Thanks,
Keith
Thanks Guys !!! yes John, it's in process now. It was in mill yesterday afternoon.. Thanks, SJ
Steve Johnson
Induction Solutions
Shop 352-593-5900
Cell 815-341-8853
Awesome....
» A-460 HEAD QUESTION
» Fogger Nozzle thread
» Exhuast Port Flange Location: A460 vs Blue Thunder
» Square port intake vs oval port
» Track report
» Track report
