SBF Crankshaft>
SBF Crankshaft>
I need a good used 3.85 stroke crankshaft for a 74 351W block 3.00 mains 2.100 rods and if the price is right a new one .
Thanks Whitey
Thanks Whitey
whitefield- Posts : 2244
Re: SBF Crankshaft>
have an Eagle forged steel 3.750 stroke crank , by chance you need rods or pistons.
the crank is new, $375. takes it plus shipping
DanH- Posts : 1081
Re: SBF Crankshaft>
Thanks ,but I already have rods and pistons . I am trying to clean up and put together some extra engine parts that I have laying around.DanH wrote:have an Eagle forged steel 3.750 stroke crank , by chance you need rods or pistons.
Re: SBF Crankshaft>
that's the next sbf I want to try , a 393 kinda a neat and cheap combo seeing how you don't need stroker rods or pistons.
nuclearcobra- BBF CONTRIBUTOR
Re: SBF Crankshaft>
that cool word cheap . there is two ways for the 393's , stock oem rods & pistons that Can be cheap .nuclearcobra wrote:that's the next sbf I want to try , a 393 kinda a neat and cheap combo seeing how you don't need stroker rods or pistons.
or the steel cranks that require aftermarket
DanH- Posts : 1081
Re: SBF Crankshaft>
They are cheap and easy to make good power with.nuclearcobra wrote:that's the next sbf I want to try , a 393 kinda a neat and cheap combo seeing how you don't need stroker rods or pistons.
,,,, Thanks Whitefield
Re: SBF Crankshaft>
you didnt say what type/specs for a 383 crank .whitefield wrote:They are cheap and easy to make good power with.nuclearcobra wrote:that's the next sbf I want to try , a 393 kinda a neat and cheap combo seeing how you don't need stroker rods or pistons.
you want the cheaper cast crank that takes the oem 351W rods or the steel thats almost 3 times the cost of the cast crank
DanH- Posts : 1081
Re: SBF Crankshaft>
The cheap that uses stock rod and 302 piston ! It is good used parts that I will be putting together just needs a cast steel crank. Thanks WhitefieldDanH wrote:you didnt say what type/specs for a 383 crank .whitefield wrote:They are cheap and easy to make good power with.nuclearcobra wrote:that's the next sbf I want to try , a 393 kinda a neat and cheap combo seeing how you don't need stroker rods or pistons.
Guest- Guest
» wtb 4340 4.300 crankshaft
» Balanced Rotating assembly
» Scat crankshaft ?
» 460 crankshaft
» 4.14 STROKER CRANK
» Scat crankshaft ?
» 460 crankshaft
