I am Looking for an FE 427 Crankshaft
Hello, all,
I am interested in buying a FE crankshaft, I remember looking it up and it was a 427 FE crankshaft.
Now, it's not SCJ crankshaft, the $800 crank, with a set of part numbers. All the crank has is a dollar sign stamped into the crank ;
If you can't find that crank, I will take a crank as close as you can get to 4 inch stroke! A little bit over, or maybe a little bit under. Just as close as you can get to a 4 inch stroke.
Thanks for your help, and especially for your time looking for a crank!
David ( Keoneeli1 ) Cawdrey
Keoneeli1- Posts : 6
Re: I am Looking for an FE 427 Crankshaft
Have you check the classified in the FE forum??....they got lots of FE goodies over there!!
BBFTorino- Posts : 997
Give Barry at Survival Motorsports a call.
» 460 crankshaft
» 4.14 STROKER CRANK
» wtb 4340 4.300 crankshaft
» Balanced Rotating assembly
» Scat crankshaft ?
» Scat crankshaft ?
