Lunati crank says for 6.8 rod will 6.7 not clear or something?
Lunati crank says for 6.8 rod will 6.7 not clear or something? Empty Lunati crank says for 6.8 rod will 6.7 not clear or something?
Post  ED468 January 26th 2014, 2:35 am
NM
ED468
Lunati crank says for 6.8 rod will 6.7 not clear or something? Empty Re: Lunati crank says for 6.8 rod will 6.7 not clear or something?
Post  rmcomprandy January 26th 2014, 11:26 am
ED468 wrote:NM
They are saying, with a shorter rod than a 6.800" that the wrist pin boss of the pistons will come into contact with the counterweights.
Lunati crank says for 6.8 rod will 6.7 not clear or something? Empty 6.8 rod for crankshaft
Post  ED468 January 27th 2014, 11:05 am
Thanks Randy that what I figured. But remember reading all aftermarket cranks while back used the 2y size throws< guess it might be tight in a d9 block as well :}
ED468
Post  Carl January 27th 2014, 12:12 pm
I've built several engines with Lunati 4.500 cranks and 6.700 rods.  Clearance is not an issue.  The counterweight size is based on the 3Y cranks (more compact), so it'll fit in any production block.  This is true of all aftermarket BBF stroker cranks.
Carl
Post  rmcomprandy January 27th 2014, 3:42 pm
Carl wrote:I've built several engines with Lunati 4.500 cranks and 6.700 rods.  Clearance is not an issue.  The counterweight size is based on the 3Y cranks (more compact), so it'll fit in any production block.  This is true of all aftermarket BBF stroker cranks.
You should call LUNATI and advise them their crankshaft instructions are erroneous and that they have no idea of what they are talking about for their crankshafts.
Post  Carl January 27th 2014, 4:47 pm
I could call, but it wouldn't make a difference.
Just another example of why it pays to deal with a specialist instead of a phone jockey at some huge warehouse.
 Wink
Carl
