Lunati Crankshaft problems
kjett
Will Brewer
Don't know if anyone has had similar probem or not.just tried fitting crank in block before sending it for balancing.The radius on #4 main journal on the crank hits the saddle of the block. Wont turn at all. Returning to summit and getting a Scat..
Will Brewer- Posts : 14
Re: Lunati Crankshaft problems
Why not just get the crank fitted to the block with the bearings/clearances you want?
kjett- Posts : 1169
Have pictures ?
Lunati crank problems
Its an A460 block .Wish I had taken a picture. No problem with the block.My Scat crank spins perfectly.
I had the same issue with the 1st batch[s] of Scat forgings....many years ago. The cast Scat shaft would spin fine. Seems someone forgot how to finish the cranks to accomadate the wider 2 & 4 main bulkheads of the A460 blocks. The issue at Scat has long since been resolved.
I guess someone should call lunati and tell them.
Will Brewer wrote:I guess someone should call lunati and tell them.
Yes, you should......
QtrWarrior- Posts : 2702
Call Jon Kaase's shop they have see quite a few if them. They would know
Ace
Ace
powerstrokeace- Posts : 1496
My eagle crank had this problem also , I had .020 or .025 milled off the side of the cap and block
10SHOTS- Posts : 587
» Lunati Cam id for a 429 help
» Lunati cam info
» '71 429 cobra jet engine - correct cam shaft to use today...
» Scat crankshaft ?
» Lunati or comp cam ?
» Lunati cam info
» Scat crankshaft ?
