Scat crankshaft ?
+10
hienergy557
kim
69BOSS
DaveMcLain
BIGINCH'S
gmsmkr
14 posters
Page 1 of 2
Page 1 of 2 • 1, 2
Scat crankshaft ?
What is the weight difference in the SCAT superlight forged crank vs a SCAT standard forged crank
gmsmkr- Posts : 1364
Re: Scat crankshaft ?
No body knows..... it's a 400$ price difference
Weight reduction does come to mind. But that just my keen sence for the obvious coming out.
gmsmkr wrote:No body knows..... it's a 400$ price difference
I would make a bet that SCAT knows ... give them a call.
http://www.survivalmotorsports.com/scatcrank06.pdf About 6lbs less on a 4.5" stroke BBC. Can't find any BBF weights on the net for some reason.
supervel45- Posts : 4498
[/quote] I would make a bet that SCAT knows ... give them a call.[/quote]
Scat won't say I have called them... this why I posted it here
Yep I just find it odd my self and scat won't even talk about the lightweight stuff for the bbf
supervel45 wrote:http://www.survivalmotorsports.com/scatcrank06.pdf About 6lbs less on a 4.5" stroke BBC. Can't find any BBF weights on the net for some reason.
Summit has them for about $240 more, with free shipping. I would not pay that much more either for a few pounds less.gmsmkr wrote:No body knows..... it's a 400$ price difference
scat lightweight
A couple years back I inquired about the lighter crank and was told it was a weaker piece in a max effort deal
BIGINCH'S- Posts : 31
I would say that if you're building a large displacement engine that really crankshaft mass isn't a huge factor. The displacement is high relative to the mass and inertia of the crankshaft weather you deliberately try to lighten it or not. The money is probably best spent elsewhere where it can do more good when it comes to performance.
DaveMcLain- Posts : 399
Scat Vs Lunati
Scat and Lunati Std weight 4.5 stroker, are they the same import forgings, they both look ok but the lunati is about $300 cheaper. From what I have read balancing could be an issue. If I have to spend a lot to balance due to adding heavy metal would I be better off to spend extra and get a Callies Magnum USA made crank, $1800 but maybe no issues with balancing???? Any thought's or first hand experience would be appreciated. Also looking at Callies Compstar rods which look to be real nice for $600.
69BOSS- Posts : 75
We had to take over 3lbs out of my SCAT billet crank.... sometimes it isn't the heavy Mallory in.
kim- Posts : 700
69BOSS wrote:Scat and Lunati Std weight 4.5 stroker, are they the same import forgings, they both look ok but the lunati is about $300 cheaper. From what I have read balancing could be an issue. If I have to spend a lot to balance due to adding heavy metal would I be better off to spend extra and get a Callies Magnum USA made crank, $1800 but maybe no issues with balancing???? Any thought's or first hand experience would be appreciated. Also looking at Callies Compstar rods which look to be real nice for $600.
I've used both Scat and lunati. Not the same forging.
hienergy557- Posts : 179
Since you have used both, do you like one better than the other and why? Also, do you what size the pilot hole is at the back of the crank? I am running a stick so the hole needs to be about 1.85 and .500 deep.
Thanks,
Staci
Thanks,
Staci
69BOSS- Posts : 75
DaveMcLain wrote:I would say that if you're building a large displacement engine that really crankshaft mass isn't a huge factor. The displacement is high relative to the mass and inertia of the crankshaft weather you deliberately try to lighten it or not. The money is probably best spent elsewhere where it can do more good when it comes to performance.
X2
hienergy557 wrote:69BOSS wrote:Scat and Lunati Std weight 4.5 stroker, are they the same import forgings, they both look ok but the lunati is about $300 cheaper. From what I have read balancing could be an issue. If I have to spend a lot to balance due to adding heavy metal would I be better off to spend extra and get a Callies Magnum USA made crank, $1800 but maybe no issues with balancing???? Any thought's or first hand experience would be appreciated. Also looking at Callies Compstar rods which look to be real nice for $600.
X2 The Lunati crank has a lot nicer, cleaner finish than the Scat. I balanced one to 2260 gram bob weight no problem. But that's a very light bob.
Correction, I was comparing the Lightweight to the Ultra Lightweight. Sorry about that.supervel45 wrote:http://www.survivalmotorsports.com/scatcrank06.pdf About 6lbs less on a 4.5" stroke BBC. Can't find any BBF weights on the net for some reason.
The Lunati looks a better piece. Nicer finish. Machining looked and measured better.
No problem balancing. I can't remember the bob weight but it's a 4.5" Diamond flat top and a Callies I beam steel rod.
I think I will be going with a lunati crank it looks to be much better.
Thanks for the info. I ordered a Lunati crank. Also got a set of P-51's on the way.
69BOSS- Posts : 75
I've sold several of the Lunati crankshafts. Nobody has had to add any wt. to them.
Good quality machining on the Lunati
The Lunati in my engine was very nice and balanced without issue. Now if they would make a 4.750 stroke version I would be all over it.
460pulling- Posts : 249
Sounds like a nice crank for the money. I can hardly wait to get it. I have been looking at bearing's and am considering Clevite "V" series, they offer .001 or .002 extra clearance and no groove. I don't know what clearance the std H or V series bearings would have as compared to a stock replacement bearing. I know most stock replacement bearings will yield about .001 to .0015 clearance, I am shooting for .003 to .0032. Can anyone tell me should I start with a .001 extra clearance bearing or .002 when using the H or V series bearings???
69BOSS- Posts : 75
Page 1 of 2 • 1, 2
» SCAT CRANK KEY"S
» scat forged superlight crankshaft
» Scat Forged 4340 Crankshaft, 4.50 stroke - SOLD
» steel 429 truck crankshaft, bathtub oil pan/pickup tube, 6.800 scat BBC h-beam rod wanted
» How to tell if a motor is externally or internally balanced
Page 1 of 2
