Lunati Cam id for a 429 help
I got a Lunati cam with a trade and cannot find the specs on the Lunati site and they cannot find the # in their system.
Lunati Cam SP71 ? N3DT 300-310 Advertized - 110 Lobe Seperation has a purple stripe on the on the
stick.
#1 lobe = 1.460 Base Circle 1.781 x1.7 Rocker Ratio Lift = .545
#2 = 1.480 1.780 x1.7 = .510
Anyone know what this cam might be?
stick.
75truck- Posts : 102
Re: Lunati Cam id for a 429 help
75truck wrote:I got a Lunati cam with a trade and cannot find the specs on the Lunati site and they cannot find the # in their system.
stick.
A camshaft with custom chosen lobe profiles ground by LUNATI will NOT be found on their website.
Beside that ... Lunati changed their numbering system when they were bought by Holley and then changed to another after they split from Holley to go out on their own, again.
SO, the age of that cam will also make a large difference.
If you send it to me I'll plot it for you.
DaveMcLain- Posts : 399
stick.
Sounds about like about the only specs. you are lacking are ICL and .050" duration?
supervel45- Posts : 4499
Anyone have a old Lunati cam book th.....
Anyone with an old Lunati cam book that can look up this cam?
Thanks in advance,
Bob
Tucson
Thanks in advance,
Bob
Tucson
http://www.lunatipower.com/SearchResults.aspx?search=sp71n3dt
See if you can find a part number on it. I don't know on the customs but, I doubt it will show here. Might have to break down and put it on a cam doctor.
Numbers on the front end of cam
These 2 set of numbers were engraved on the front of the cam , SP71 N3DT. Along with the 300-310 110.
So who would have an old catalog?
Thanx,
Bob
Tucson
Thanx,
Bob
Tucson
75truck wrote:These 2 set of numbers were engraved on the front of the cam , SP71 N3DT. Along with the 300-310 110.
Thanx,
Bob
Tucson
I have a old Lunati Catalog but like Randy mentioned if it's a custom grind it will not show it in the catalog.
Mark Miller- Posts : 1958
» '71 429 cobra jet engine - correct cam shaft to use today...
» Lunati 72412
» Scat crankshaft ?
» Lunati 51605 ?
» Lunati cam info
» Lunati 72412
» Scat crankshaft ?
» Lunati 51605 ?
» Lunati cam info
