Lunati 72412
Lunati 72412
The downside to building a car from the ground up (and trying to do it inexpensively) is buying parts when you find a deal and packing them away until they're needed later. That's where I am on finding a set of Lunati 72412 solid roller lifters. I'm re-doing the frame and rear suspension, but will need lifters in the (hopefully) not too distant future. Application is a 545, SCJ heads, 10.5:1 forged '32 3 window that'll be about 95% race.
I've read a lot about different roller lifters and issues with street duty, spring pressure, needle bearing vs bushed, etc. Question is, are these Lunati's a good fit for a budget 750ish hp drag motor?
Slowride- Posts : 32
Re: Lunati 72412
Slowride wrote:The downside to building a car from the ground up (and trying to do it inexpensively) is buying parts when you find a deal and packing them away until they're needed later. That's where I am on finding a set of Lunati 72412 solid roller lifters. I'm re-doing the frame and rear suspension, but will need lifters in the (hopefully) not too distant future. Application is a 545, SCJ heads, 10.5:1 forged '32 3 window that'll be about 95% race.
They'll be just fine.
» Lunati Cam id for a 429 help
» -lunati sbf cam
» Lunati 51605 ?
» Lunati cam info
» '71 429 cobra jet engine - correct cam shaft to use today...
» -lunati sbf cam
» Lunati 51605 ?
» Lunati cam info
