Lunati 51605 ?
Lunati 51605 ?
Got cam with other stuff in tade. Can not find any specs on it. Called Lunati they couldnt tell me anything about it.Anybody have any info? Thanks
Green 72- Posts : 41
Re: Lunati 51605 ?
https://www.lunatipower.com/Product.aspx?id=2293&gid=253 Sorry not the same one but, the old part number is very close and I suspect it was from the same series.
supervel45- Posts : 4497
Re: Lunati 51605 ?
Sure it's not a 31605?
http://www.lunatipower.com/CamSpecCard.aspx?partNumber=31605
Jess
Jess
Mustang-junky- Posts : 438
Re: Lunati 51605 ?
Green 72 wrote:Got cam with other stuff in tade. Can not find any specs on it. Called Lunati they couldnt tell me anything about it.Anybody have any info? Thanks
I found it in a older Lunati Catalog i have.51605 Solid roller for 429-460,RRZ-276-284 is the grind number..795 int-.735 exh lift 276 int.-284 exh. duration at .050 lift.Good truck pull or Super Comp Cam for 500 ci. and up engines.Power Range 4,500-8,000 rpm.
Mark Miller- Posts : 1948
Re: Lunati 51605 ?
Was the LSA/ICL 108/104 like the 51606 I linked? Looks like they are almost identical accept for the higher intake lift.
Re: Lunati 51605 ?
supervel45 wrote:Was the LSA/ICL 108/104 like the 51606 I linked? Looks like they are almost identical accept for the higher intake lift.
The 51605 LSA/ICL is 110/106
Re: Lunati 51605 ?
Thanks for info.Found numbers on ether side but not 51605. Thanks again.
Re: Lunati 51605 ?
the 61605 is fairly common cam. Maybe that 5 is a 6?
rmk57- Posts : 176
» Lunati Cam id for a 429 help
» Lunati 72412
» Scat crankshaft ?
» Lunati cam info
» '71 429 cobra jet engine - correct cam shaft to use today...
» Lunati 72412
» Scat crankshaft ?
» Lunati cam info
