Streetmaster 460 on D0VE heads
Streetmaster 460 on D0VE heads Empty Streetmaster 460 on D0VE heads
Post  Bigred69 November 10th 2013, 7:55 pm
I bought a Streetmaster intake manifold for my 429. It has the rectangular exits going into the heads, and my heads are oval I believe , the same as a D2VE head. What gasket will I need to use.?
Bigred69
Bigred69
Streetmaster 460 on D0VE heads Empty Re: Streetmaster 460 on D0VE heads
Post  69F100 November 10th 2013, 10:02 pm
1230 fel pro for Dove heads. 1231 for cj heads the intake not being oval not sure need to make sure it will seal around the ports
Post  IDT-572 November 10th 2013, 10:34 pm
If your going for anything other than gas mileage, you may want to go a different route. Here is some info on that intake.
http://www.460ford.com/forum/archive/index.php/t-105992.html
Post  dfree383 November 10th 2013, 10:52 pm
X2 you need to think about a performer or performer rpm.
If you want a low single plane, the Current Torker 2 is a decent piece too.
Post  Bigred69 November 11th 2013, 9:08 am
Not really looking for big hp, just a street cruiser.
Bigred69
Bigred69
Post  dfree383 November 11th 2013, 1:58 pm
Bigred69 wrote:Not really looking for big hp, just a street cruiser.
The factory intake is a better piece.
Post  IDT-572 November 12th 2013, 12:26 pm
x2
Post  Bigred69 November 12th 2013, 1:00 pm
You guys think the stock dove-9425 will give me better performance? Can you explain? I'm new to this and just want to understand.
Bigred69
Bigred69
Post  dfree383 November 12th 2013, 1:15 pm
Yes, the factory intake will go down the track faster, like Blake was trying to explain to you before, the street masters are for mileage not performance. They are too small for a BBF.
Post  IDT-572 November 12th 2013, 1:16 pm
Bigred69 wrote:You guys think the stock dove-9425 will give me better performance? Can you explain? I'm new to this and just want to understand.
Yes, the runners are very small on the street Master to speed the air up and help off idle response and low ent torque and fuel mileage. It will be down on power over a stock intake or performer.
Post  IDT-572 November 12th 2013, 1:17 pm
You treed me lol
Post  dfree383 November 12th 2013, 1:18 pm
cheers
Post  Bigred69 November 12th 2013, 2:08 pm
I did notice from looking at the intake passages that they were kind of small compared to the stock intake. Well, that makes sense now. Thanks for clearing that up.
Bigred69
Bigred69
Post  IDT-572 November 12th 2013, 2:55 pm
Lay a stock 302 gasket on it to compare.
Post  supervel45 November 25th 2013, 5:00 am
Those manifolds I think came out after the 1973 opec. oil embaro in the mid to late 70's when people were scrambling, for anything to improve gas mileage. No reason to run a BBF now if gas mileage is a top concern. Back then we had to, or buy a small econo box, or go to a smallblock. I would sell it or trade it for a better intake, like mentioned the factory piece was better for performance. It would almost be a sin against humanity, to bolt it to CJ/SCJ heads if you have any, even if it would seal up.Suspect
Post  Bigred69 November 25th 2013, 7:41 am
Already sold it and bought performer . Thanks
Bigred69
Bigred69
