PG input shaft
steven gregoire
Tommyj466
PG input shaft Empty PG input shaft
Post  Tommyj466 November 18th 2013, 4:48 pm
I have a powerglide with a 1.96 low gear set (straight cut), and a hardened glide input shaft. I think I want to switch to a turbo input shaft. Is this a simple plug and play deal or what?
I also have a PA SFI bell that I used on my C4 that I plan to use with the PA adapter ring. Is anyone familiar with this set-up? Will I need anything special converter or flexplate wise?
Tommyj466
Tommyj466
PG input shaft Empty Re: PG input shaft
Post  richter69 November 18th 2013, 7:28 pm
shaft should be plug n play, just get the same length and type (ring style or ringless)
not familiar with the adpater ring, easiest way is to get a bbf/glide ultrabell and use a reg chevy converter and a jw wheel.
Post  cool40 November 18th 2013, 9:08 pm
It is nice to be able to use a gm converter. When you need 3 shots at getting the stall right. Laughing
Post  steven gregoire November 23rd 2013, 9:40 pm
the Turbo spline shaft is the same at the PG spline shaft. plug and play. there are 2 different length input shafts thou.. but that depends on your gearset type
steven gregoire
steven gregoire
Post  richter69 November 24th 2013, 12:13 am
splines are different on the converter end, the trans side is the same. most aftermarket shafts are universal.
Post  the Coug December 1st 2013, 2:10 am
Tommy just a note if you pull the input shaft while it is laying on the Pan you screwed up. It has a thrust washer in the planetary the input goes thru and if pulled laying down it will drop, if you Remove or wish to remove it stand trans on end the washer will stay in place, So in the end it is not just a plug and play deal, if you allready pulled it get ready to pull the trans apart to center the thrust washer...if you have been in one of them you would know this....
have a nice day
Post  richter69 December 1st 2013, 4:01 am
You can work it back in place if it slips.... Which i doubt it will.
Post  Dave C. December 1st 2013, 5:09 am
Dont you guys ever sleep? Shocked
Dave C.
Post  res0rli9 December 1st 2013, 5:14 am
Dave C. wrote:Dont you guys ever sleep? Shocked
Nope...Stay up 24/7
Post  the Coug December 1st 2013, 5:58 am
Jon just how many Glides have you built? 0 like I thought. lol
Dave whats sleep? I got 3 hours yesterday maybe same today. plenty time to sleep when I am dead Laughing
Post  Dave C. December 1st 2013, 6:13 am
I agree. Making a pot of coffee as we speak.
Dave C.
Post  cool40 December 1st 2013, 11:43 am
I guess I got lucky 3 times.when I pull the converter out the shaft always come out too.never had any problems with it.
Post  richter69 December 1st 2013, 12:02 pm
the Coug wrote:Jon just how many Glides have you built? 0 like I thought. lol
two in the last 3 weeks, I got 4 to do sitting in the shop right now.
Ill be glad to throw some pics up as I go along if you like.......
Post  69F100 December 1st 2013, 9:42 pm
They might be like me work at night and can't sleep when not working because the sleep habit is all screwed up.Embarassed
Post  DILLIGASDAVE December 3rd 2013, 1:04 am
I worked mostly midnight shift for over 20 years, hard habit to break. Laughing
