TFS Mafia heads
+10
Race Ready Fabrications
KY JELLY
56Tbird
Larry T
larry552
Moodyblues
14 posters
TFS Mafia heads Empty TFS Mafia heads
Post  Moodyblues November 20th 2013, 6:10 pm
I might go in another direction and may look to sell the "original TFS Mafia heads." Lot of work went into these heads. 499 Ford, 2500 lb chassis car it ran 5.44/125 on gas. These are excellent heads. Feel free to ask Blake the Snake and Dan Hobbs about them. $2500 I do not know the flow numbers, but they're good.
Russ
423-718-3279 cell - text or call
Moodyblues
Moodyblues
http://www.russhoodinsurance.com
TFS Mafia heads Empty Re: TFS Mafia heads
Post  Moodyblues December 5th 2013, 11:15 am
Moodyblues
Moodyblues
Post  Moodyblues December 5th 2013, 11:20 am
New price $2200
Moodyblues
Moodyblues
TFS Mafia heads Empty tfs heads
Post  larry552 December 5th 2013, 1:29 pm
Any pics. I'm looking into selling my p-51. I'm was looking into buying a se of A460
larry552
larry552
Post  schmitty December 5th 2013, 2:05 pm
These hesds are TFS Streets that were worked over by Charlie as a prototype.
Post  Larry T December 5th 2013, 5:17 pm
Moodyblues wrote:I might go in another direction and may look to sell the "original TFS Mafia heads." Lot of work went into these heads.   499 Ford, 2500 lb chassis car it ran 5.44/125 on gas.  These are excellent heads.  Feel free to ask Blake the Snake and Dan Hobbs about them.   $2500 I do not know the flow numbers, but they're good.
Russ
do you have the tfs intake for sale as well?
Larry T
Larry T
Post  Moodyblues December 5th 2013, 6:04 pm
Mine is a port matched victor
Moodyblues
Moodyblues
Post  Moodyblues December 27th 2013, 4:44 pm
BUMP. I have pics I can text or email
Moodyblues
Moodyblues
Post  738drvr December 30th 2013, 4:17 pm
I have a copy of the flow sheet on these heads from Charlie. Very good numbers.
Post  56Tbird December 31st 2013, 12:01 pm
schmitty wrote:These heads are TFS Streets that were worked over by Charlie as a prototype.
Wrong heads Cowboy,these were Randy Moore's heads when they were new.I bought them from Randy.They are a great set of heads! They make killer power! king Charlie did do the 1st porting on them ,then Blake the Snake got a hold of them!
56Tbird
56Tbird
Post  Moodyblues December 31st 2013, 12:51 pm
They do make great power, Im just going bigger or I would not let them go.
Moodyblues
Moodyblues
Post  738drvr December 31st 2013, 7:09 pm
Actually cowboy, didn't Charlie work on one and Blake also got one to work on? There's a story there but I'm not going to spill the beans...
Post  the Coug December 31st 2013, 9:30 pm
actually these are not the experimentals these are just a set of casting that were ported nothing special....
Post  KY JELLY December 31st 2013, 10:07 pm
I thought they was pretty special lol. They won the big block bash , made the qk 16 , spanked bobby z ,spanked bruno,and spanked ole hobbs too lol. They are not the exp castings , but i would say as good as any tfs streets out there .
KY JELLY
KY JELLY
Post  Race Ready Fabrications January 1st 2014, 10:03 am
schmitty wrote:These hesds are TFS Streets that were worked over by Charlie as a prototype.
I own the 'prototype mafia' heads that have the welded and raised intake runners.  Cool
Post  the Coug January 1st 2014, 11:40 am
Randy these are great heads, I know they can build over 850 hp with them easy.....they are well ported and work. Brian has the experimentals
Post  Moodyblues January 1st 2014, 1:28 pm
They're good heads or they wouldn't go 5.44 and that was with a small cam .737/.727.
Russ
423-718-3279 cell. I have pics
Moodyblues
Moodyblues
Post  56Tbird January 1st 2014, 1:51 pm
Moodyblues wrote:New price $2200
Great buy on this set of heads!! Somebody needs to grab them !!
56Tbird
56Tbird
Post  c.evans January 1st 2014, 4:29 pm
True that. Brian owns the Prototype Mafia heads. They were welded, raised runner, long valves, raised valve spring seats, etc.. Blake and I did the dyno testing of the heads and intake manifold and then made the presentation in the conference room at TFS in Talmadge. Due to the economy and the cost of retooling, they said no to the heads, but yes to the intake manifold. Many of you run the TFS Mafia intake manifold today, and it has proven to be anywhere from 12 to 20 Hp better than a ported Victor,,,,on all out race engines.
Uncle Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  IDT-572 January 1st 2014, 9:12 pm
These are a better set of heads than the ones I made 861 hp with, they ran that 5.44 on a 501 inch engine short shifting.
These heads have great air speed for good hp on a 500 to a 550 inch engine. My engine, a 557 had a 1700 rpm spread from tq peak to hp peak with a set close to these.
They would make someone a great set of heads for the money........... Cool
Post  MustangDan January 1st 2014, 9:41 pm
what's the difference in the regular a 460 TFS had and the Mafia had
MustangDan
Post  70FB January 2nd 2014, 8:17 pm
Would these work on my A429 engine???? "piston wise"? I need to add 3/10ths to my combo. Currently 727 lift. 13.6-1.
70FB
70FB
Post  Moodyblues January 2nd 2014, 9:53 pm
70FB wrote:Would these work on my A429 engine???? "piston wise"? I need to add 3/10ths to my combo. Currently 727 lift. 13.6-1.
Im not sure
Moodyblues
Moodyblues
Post  c.evans January 2nd 2014, 11:33 pm
Yes they would "piston wise" because the valve reliefs are in the same location as your A-429 heads. Now then,,,if your pistons have a dome on them, then as always you need to check your dome to chamber clearance and sand the domes if necessary.
Hope this helps,
Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  Moodyblues January 3rd 2014, 11:50 am
Heads are SOLD pending payment.
Moodyblues
Moodyblues
