4 wheel disc brake plumbing
4 wheel disc brake plumbing Empty 4 wheel disc brake plumbing
Post  frank13 November 1st 2009, 11:21 am
ok i need to plumb the brake system today. below is my crude drawing of my plan.
4 wheel DISC brakes
cobra master cylinder
manual brake conversion with correct pedal
all original rear brakes and lines
I do have a proportioning valve from wilwood, but unsure if needed, or where to place
I need to plumb this today if you see something wrong please post, or call me!!!! 4843189865 Frank
4 wheel disc brake plumbing Brake
frank13
frank13
http://www.frankskinkracing.com
4 wheel disc brake plumbing Empty Re: 4 wheel disc brake plumbing
Post  jbozzelle November 1st 2009, 11:54 am
Stick the prop valve in the rear lines. It's used to cut down the pressure going to them so the car doesn't lock up the rears and try to swap ends on you.
What kind of car if it?
Post  frank13 November 2nd 2009, 1:09 pm
thanks!!!!
frank13
frank13
