Crank pulleys
Crank pulleys
I'm looking for a 1 slot vbelt crank pulley that will bolt to the 4 hold balancer for the alternator and also v belt pulleys and spacers that will fit on a 1" drive mandrel from Ron's.
I have an aerospace mandrel that has what I need but won't work with the crank bolt in place. ( I even made a 1/4" spacer for the balancer and recessed the mandrel some more.
Can anyone help with a solution?
Re: Crank pulleys
I think I figured out what I'm gonna do. I showed it to the machinist at work, and he's gonna drill the center hole out for the std. 5/8 bolt. Now I'll just have to come up with the correct length 5/8" fine thread bolt.
Re: Crank pulleys
I've cut them to length before.
Alan,measure the length. I probably have a xtra one .
Re: Crank pulleys
Thanks Rick, the machinist should have the aerospace mandrel modified today, so I'll be able to measure the bolt length I'll need tonight.
» Alternator and Crank pulleys for a Drag application.
» differences in 68-69 crank pulley to 70 and up crank pulley for Lincoln with crank PS
» Crank pulley for racing alternator
» WTT hawks/RPM 4.5 stroke cast crank for 4.150/514 crank
» Factory brackets and pulleys
