Radiator for my 69 fairlane
Looking for ideas on a radiator for my 429 going into my 69 fairlane. Would a 3 core be enough for a stockish 429. Stock lower end, with ported C8 heads, Edlebrock performer, and Holley 750 . Have looked at the ones on Fleebay ,but don't know the quality of any of them. I also plan on using a pull type electric fan.
Bigred69- Posts : 70
Re: Radiator for my 69 fairlane
Be sure you put a good shroud on it.. The 3 core should work fine..
Dave C.- Posts : 1268
look at Crites
On my 66 cyclone I went with an aluminum radiator that Crites restoration offers .It is a Howe and fit really good .It comes with some brackets and a hold down .And like the other poster said you need a shroud .Crites has a lot of parts available to install 429-460 in cars like yours.Good luck to you !Doug
manofmerc- BBF CONTRIBUTOR
69 Torino R-Code Radiator
I've got an R-Code radiator and shroud that I'd part with if you think that will do the job.
mkopmani- Posts : 37
mkopmani wrote:I've got an R-Code radiator and shroud that I'd part with if you think that will do the job.
Wow, I just bought a 2 row aluminum with 1" tubes last night.
