Horsepower?
Horsepower? Empty Horsepower?
Post  Bigred69 December 9th 2013, 9:01 am
Just trying to find out what horsepower I may be dealing with on my 429. It basically is a stock 72 429, with straight up timing set, stock cam ,pistons, exhaust, with Edlebrock performer, and new 750 Holley. It has C8 heads that have been ported , and new stock stainless Ford valves. It has a stock C6 tranny bolted up to it. I was just curious if anyone could tell me what kind of power this thing is gonna make. Not expecting a lot , it's going in a weekend cruiser.
Bigred69
Bigred69
Horsepower? Empty Re: Horsepower?
Post  supervel45 December 9th 2013, 11:10 am
I have a 429 close to yours but with D2 heads and SCJ intake with a mild to medium cam, with headers. Glad somebody else plays with the little Big Blocks. If your block has not been decked with the C8 heads I would estimate 9.5 to 10/ compression. Factory was 10.5 or so on the shorter early deck, small chamber engines. The 1968-70 429's stock were rated at 360 net. Gross HP would have been around 290-300hp or so. With mild head porting, with stock exhaust, I doubt you will gain alot of HP and the Performer intake is not much over stock. The 750cfm carb may help some if the gearing, vehicle weight get along. I would guestimate 325Hp on a good day. Gas mileage should be better than alot of the radical monsters around here though.
Post  Bigred69 December 9th 2013, 1:13 pm
Humm, I guess I'm trying to figure out how the horsepower went down from net to gross hp. Did you mean to say 360 gross hp? I thought I would have been at least close in hp to the earlier motors that were rated at 360hp ,or even better with added porting and airflow.
Bigred69
Bigred69
Post  supervel45 December 9th 2013, 11:24 pm
I am sorry for that. I got them backwards. You should be around or above the 360 gross factory rating. I was using the 325 net HP as an example. The old rule of thumb was to subtract 60-70hp from the gross to equal the net.
Post  Bigred69 December 10th 2013, 9:55 am
Well, I know of figured that, but wanted to make sure. I think this motor will be plenty for what I'm doing.haha
Bigred69
Bigred69
