ARP 2000 rod bolt upgrade
ARP 2000 rod bolt upgrade Empty ARP 2000 rod bolt upgrade
Post  mikey hefner December 22nd 2013, 12:23 am
Hi everyone, just picked up a set of Scat H Beams from one of the members here. How difficult is it to add the ARP2000 bolt upgrade to them? I'm still learning so please don't think I'm ignorant for asking what may be a simple question. Any info is appreciated! !!
mikey hefner
ARP 2000 rod bolt upgrade Empty Re: ARP 2000 rod bolt upgrade
Post  bbf-falcon December 22nd 2013, 4:03 am
There's not a dumb question when trying to learn.Lem can fix you up with your 2000 bolts.
Post  mikey hefner December 22nd 2013, 11:16 am
What needs to be done to the rods to install the bolts if anything?
mikey hefner
Post  Lem Evans December 22nd 2013, 11:39 am
Check the big end for size after the new bolts are installed...should be okay.
Post  mikey hefner December 22nd 2013, 12:43 pm
So they will thread in no problem, check for out of round after, and resize if needed? Am I correct in my thinking from what you guys have shared.
mikey hefner
Post  Lem Evans December 22nd 2013, 7:40 pm
The 8740 and 2000 bolt threads are the same.
Post  mikey hefner December 22nd 2013, 9:46 pm
Why will it distort the cap when installed?
mikey hefner
Post  Lem Evans December 24th 2013, 2:51 pm
It is wise to measure to find out if the bore distorts.....that's the only way to know for sure.
Post  DILLIGASDAVE December 25th 2013, 1:05 am
What is the strength difference between the bolts that come with the Scat/Eagle type H-beam rods & the ARP 2000 bolt? Are we talking about a small increase in bolt lifespan/loading/safety, or a huge difference?
Post  mikey hefner December 25th 2013, 1:41 am
From what I understand the ARP 2000 Bolts take the power handling to four digit power range. I'm definitely upgrading!!
mikey hefner
Post  richter69 December 25th 2013, 2:23 pm
Wel they handled my deal and survived a good bit of rpm.
