Rod bolt and cam bolt torque?
jones
What should the rob bolts be torqued to on a 6.8 Eagle? It's not the L19 or 2000 bolts. I think they are stamped 7840?
Also what about a 9/16 fine thread cam bolt?
jbozzelle- Posts : 3705
Re: Rod bolt and cam bolt torque?
The cam bolt is a 7/16 fine thread, red loctite, 65ish ftlbs. Be sure to use a grade 8 bolt with plenty of thread.
Rod bolts should be 64ish with moly.
I've got a full thread bolt and thick washer.
Any rod torque value for 30 wt? Or is this where you would only use moly?
John, do yourself a favor and use ARP lube. It will help with your accuracy of pulling torque.
Curt- Posts : 2791
Should I completely clean the 30 wt off with brake cleaner? I've already assembled the shortblock. Just have the rods hand tight because I didn't have the torque values.
should be able to just smear on the moly.
For kicks and giggle just make sure your cam bolt isn't bottoming out. Especially if your not using the essentric.
jones- Posts : 2230
Thanks Dave. Jones, I checked that too!
http://www.eaglerod.com/index.php?option=com_content&task=view&id=24&Itemid=25
tiger- Posts : 272
I don't care for the moly stuff on head or main bolts/studs but like has been said use the stuff the mfr. recommends on rod bolts.
Thanks guys. I'll get after it tomorrow night.
if you get in a bind and have to use 30wt = 80lbs tq for the rod bolt
DanH- Posts : 1081
It jumps that much using oil instead of moly ?
nuclearcobra- BBF CONTRIBUTOR
» Head bolt torque and Copper gaskets
» new comp cam bolt torque
» Rod bolt torque?
» flywheel bolt torque
» 4 bolt kit torque specs ?
» Rod bolt torque?
