Head bolt torque and Copper gaskets
What is the proper torque value for BBF head bolts?
Also any suggestions on installing new copper head gaskets. Technique, sealants. The heads are Blue Thunders with o rings.
falconracer- Posts : 19
Re: Head bolt torque and Copper gaskets
in steps 70 -110 - 140 with oil
What is your combo? With blown alcohol we o-ring the block and have receivers in the heads.
I've always been running them dry but I don't run water.
Did it also on a monstertruck one time and after a couple of heat cycles we retorqued them and the didn't leak also.
bolt torque
Carb only no power adders. dragrace only. runs 5.50s in 1/8th. I do use water so I don't want no leaks. Heads are oringed only.
no comment leave it to the other people to say....
the Coug- Posts : 3055
gaskets
with the heads already oringed im not sure i can do cometics...plus i got to have a certain thickness that only i found in copper
falconracer wrote:with the heads already oringed im not sure i can do cometics...plus i got to have a certain thickness that only i found in copper
How deep is the o-ring groove? Aluminum heads? If so, have the groove welded shut and surface them and use the Cometics. Lem can get many different thicknesses in the Cometics as well. Copper has it's place, I'm not sure you need them.
Nevs- BBF CONTRIBUTOR
heads are alum BTs they are ready to bolt on now... just looking for help with what I have. thanks for the suggest though i considered that earlier but not welding them up, pounding copper in the groove and resurfacing was the option given by evans but i decided to go back back with the copper
falconracer wrote:heads are alum BTs they are ready to bolt on now... just looking for help with what I have. thanks for the suggest though i considered that earlier but not welding them up, pounding copper in the groove and resurfacing was the option given by evans but i decided to go back back with the copper
The copper wire in the receiver groove would work as well. Good luck with the copper gaskets, they wouldn't be my choice for sure, but it's your build.
just an FYI
Here is a pic of my BT heads after Charlie filled the grooves with copper wire and then milled them, Looked great.
Thanks for all the info.. I know Evans does good work and I may have this done during the next freshen job. For now I need to get it back ready to race, I also run Div 2. The Falcon I have won Best Engineered at 2006 Div 2 Final @ Carolina...Hope to see you at one of the races..
» COPPER HEAD GASKETS
» Copper Header Gaskets
» Cometic MLS head gaskets
» 18 head bolt torque plate
» Copper Header Gaskets for CJ/SCJ
