new comp cam bolt torque
466cj
hpwdboss1
new comp cam bolt torque Empty new comp cam bolt torque
Post  hpwdboss1 July 1st 2012, 9:43 pm
Putting in my new comp cam from Lem. Thanks Lem! 3/8" -16 bolt, correct length grade 8. What torque# should I use?
Perry
hpwdboss1
hpwdboss1
new comp cam bolt torque Empty Re: new comp cam bolt torque
Post  richter69 July 1st 2012, 9:52 pm
I wanna say the ARP bolt that size was 45 ftlbs, make sure its got a good washer under it also.
new comp cam bolt torque Empty Re: cam bolt
Post  hpwdboss1 July 1st 2012, 10:33 pm
ARP bolt, washer from brand X balancer, ARP moly under the head, red loctite on thread, 45# is where I am but I was second guessing myself and needed reassuring!
Thanks again guys!!
Perry
hpwdboss1
hpwdboss1
Post  Lem Evans July 1st 2012, 10:55 pm
loctite for sure.
Post  cool40 July 1st 2012, 10:57 pm
i never use loctite. Surprised
Post  Lem Evans July 1st 2012, 11:01 pm
cool40 wrote:i never use loctite. Surprised
No Down side that I can see.
Post  466cj July 2nd 2012, 1:10 am
Loctite cost money. LOL
X3 use the loctite
466cj
Post  Gregaust July 2nd 2012, 4:28 am
hpwdboss1 wrote: ARP bolt, washer from brand X balancer, Perry
Those washers are 7/16??????
Gregaust
new comp cam bolt torque Empty Re: Cam bolt
Post  hpwdboss1 July 2nd 2012, 9:05 am
Greg, you are correct about the 7/16" diam., but I have an additional substantial flat washer with a 3/8" hole and feel I'll be alright. Thanks guys! I should have this thing alive again in a couple of days. Very Happy
Perry
hpwdboss1
hpwdboss1
Post  cool40 July 2nd 2012, 10:14 pm
X3 use the loctite
yea,i sure would'nt want to spend any. Razz
Post  richter69 July 2nd 2012, 11:11 pm
I get loctite for free.......................
Post  466cj July 3rd 2012, 2:49 am
richter69 wrote:I get loctite for free.......................
Man some guys have all the luck!
466cj
Post  bbf-falcon July 5th 2012, 10:15 pm
[quote="richter69"]I get loctite for free
X2,and i ain't afraid to use it Shocked Laughing
Post  4604X4 July 11th 2012, 5:51 pm
hpwdboss1 wrote: Putting in my new comp cam from Lem. Thanks Lem! 3/8" -16 bolt, correct length grade 8. What torque# should I use?
Perry
I think this thread is a good place to ask a cam bolt related question. I'm swapping cams now and am wanting to use quailty parts wherever possible. So I thought it would be worth the couple of bucks to get a "good" bolt like an ARP but I can't find one in the size I need (at JEGs or SUMMIT).
What is the normal cam bolt size? OP has a 3/8-16 cam/bolt, but both of my aftermarket cams (Crane and Engel) are 7/16-24 thread.
Do I have two odd ball cams, or are all/most of the performance cams using a 7/16-24 cam gear retaining bolt? Is a grade 8 bolt desired - or is the flex/stretch of a grade 5 more desirable?
4604X4
4604X4
Post  Lem Evans July 11th 2012, 6:10 pm
There are lots of the roller cam cores that comp gets that are 3/8" bolts....all of the flat tappet ones are 3/8".
I always request that the roller cams have the 7/16" threads...if Perry's cam is a roller with the 3/8" someone @ Comp dropped the ball Evil or Very Mad
A properly installed grade 8 seems to do a good job.
new comp cam bolt torque Empty Re: cam bolt....
Post  hpwdboss1 July 15th 2012, 10:41 am
Just a little more info... Lem speced a cam for my tractor. It is a flat tappet shaft with the 3/8 bolt and two dowels. Lem said I did not really need the second dowel, but I once had pin breakage ( my fault Embarassed ) trouble and now believe in over kill! Besides, I used the new double pinnned end as a pattern to make a fixture to drill cams and timing gears.
Got the tractor running this week and pulled Friday night. New set of titan V cut tires by Ira Banter (thanks Ira). A alot more horse with fresh 472, ran really strong Very Happy . Enough bite and power to break the next link in the chain! Tranny man says he will call today with damage report, but he thinks the output shaft twisted off. It's been run in this tractor for 4 years, and was factory stuff from long ago. I don't know if there are aftermarket shafts with more strength, but that could be next. It's always one thing or another.
Thanks all!
Perry
hpwdboss1
hpwdboss1
Post  466cj July 15th 2012, 4:28 pm
You still using a C-6?
466cj
new comp cam bolt torque Empty Re: cam bolt torque
Post  hpwdboss1 July 15th 2012, 9:48 pm
Yeah still with a C6. Rules dictate automotive automatic, C6 lets me get 2.71 ratio. Trans man called today and had news that I twisted the center out of the planet carrier, so tommorrow I go to Teal Automotive for steel 6 planet and new ring gear.Hope it stays together at Preble pull next Friday!
Perry
hpwdboss1
hpwdboss1
Post  LETHAL_DOSE July 18th 2012, 11:13 am
Who does your transmission work for you? When I ran an automatic, I used Dan Dishon out of Logansport. He was very helpful it getting the C-6 tranny to live in a pulling application. I took mine to him every winter for a freshen up job. He would only replace bad components(if there were any), and charge very little to go through it. That was 1 thing I never had to worry about. Good luck
Mike
LETHAL_DOSE
LETHAL_DOSE
new comp cam bolt torque Empty Re: Cam boly...
Post  hpwdboss1 July 18th 2012, 2:02 pm
Fellow named Lyle Meece around here who's done quite a bit of aautomatic work over the years for us. Warned me about the aluminum carrier ya know, but the 2.48 gear had the same aluminum style. So in my infinite wisdom Embarassed I says " hell, it worked that way before!"
Now I'm listening better.
Thanks and have a good one!
Perry
hpwdboss1
hpwdboss1
