4 bolt kit torque specs ?
I have a motor in the shop (d1ve block) with a 4 bolt kit on it, and am wondering about torque specs on the splayed bolts. The caps are black with numbers stamped in them and the head of the splayed bolts are 12 point 3/8 with dB embossed on them. Any info would be a great help. thanks Greg
fordpwr2000- Posts : 19
Re: 4 bolt kit torque specs ?
Greg,fordpwr2000 wrote:I have a motor in the shop (d1ve block) with a 4 bolt kit on it, and am wondering about torque specs on the splayed bolts. The caps are black with numbers stamped in them and the head of the splayed bolts are 12 point 3/8 with dB embossed on them. Any info would be a great help. thanks Greg
If it is a 4-bolt kit on a D1VE block then it might have 7/16" outer bolts (even though the inner main bolts are 1/2"). If so, then the outer bolts (if 7/16") are torqued to 65 with oil.
Paul
Thanks Paul that is what we have. 65 with oil it will be
» 460 7/16 cam bolt torque specs
» Need Torque Specs
» A-460 torque specs
» does any know the torque specs
» torque specs for svo block splayed main cap bolts
» Need Torque Specs
