Best Cam options
Best Cam options Empty Best Cam options
Post  FordMudBogger15 January 9th 2014, 10:30 pm
Is there such thing as to big of a cam lift/duration? Looking for ideas on getting a custom cam done, was told if I run a .870 lift cam then I could get the valve lift I was aiming for. Just trying to find out where the best place to get a custom cam would be.
FordMudBogger15
Best Cam options Empty Re: Best Cam options
Post  IDT-572 January 9th 2014, 11:48 pm
Get with one of the engine builders on here and have all your vehicle info, head flow, gear, trans , converter, compression, anything you can think of to give to them, and they will get you a custom cam that will work with your program.
Post  powerstrokeace January 10th 2014, 11:39 am
why the focus on the .870 lift?
Ace
powerstrokeace
powerstrokeace
Post  rmcomprandy January 10th 2014, 11:42 am
FordMudBogger15 wrote:Is there such thing as to big of a cam lift/duration? Looking for ideas on getting a custom cam done, was told if I run a .870 lift cam then I could get the valve lift I was aiming for. Just trying to find out where the best place to get a custom cam would be.
OF COURSE ... the biggest mistake made by people is getting a camshaft which is to big.
Post  FordMudBogger15 January 10th 2014, 12:43 pm
Well one of the engine builders on here told me that if I was to get .870 cam then I would get the valve lift I was looking for out of the TFS A460 head. Looking for good flow numbers out of the head when I order them and it claims the valve springs are good up to .800
FordMudBogger15
Post  Moodyblues January 27th 2014, 3:18 pm
FordMudBogger15 wrote:Well one of the engine builders on here told me that if I was to get .870 cam then I would get the valve lift I was looking for out of the TFS A460 head. Looking for good flow numbers out of the head when I order them and it claims the valve springs are good up to .800
The TFS A-Head springs say they are good to .850 lift on Summit
Moodyblues
Moodyblues
http://www.russhoodinsurance.com
