Dual Quads on a 460
+8
Carl
LivermoreDave
kim
bigblok2000ranger
dragsterdick
12 posters
Page 2 of 2 Previous  1, 2
Dual Quads on a 460 - Page 2 Empty Blue Thunder Dual Quad Source
Post  supervel45 January 18th 2014, 2:16 pm
http://www.ebay.com/itm/Ford-429-460-BT-DUAL-QUAD-INTAKE-/140978204818#ht_537wt_988                  Found it. Don't know if he has any more, but on his site he had all kinds of Rare Ford intakes.
Dual Quads on a 460 - Page 2 Empty NSS Rules
Post  dragsterdick January 18th 2014, 11:31 pm
I am sorry Dave !! Come out and join Victory and race with us.
dragsterdick
Dual Quads on a 460 - Page 2 Empty Re: Dual Quads on a 460
Post  4thHorseman January 22nd 2014, 10:44 am
supervel45 wrote:
I would think on  something like on top of a 8-71 in a T-Bucket with a Big Block would be cool.
 Twisted Evil
4thHorseman
4thHorseman
Post  512Fairlane January 26th 2014, 9:55 pm
Just looked at Victory NSS Association's website. They have 2 races at Gateway this year. Charlie how would that Blue Thunder intake work on my combination?
512Fairlane
512Fairlane
Post  c.evans January 26th 2014, 9:58 pm
512Fairlane wrote:Just looked at Victory NSS Association's website.  They have 2 races at Gateway this year.  Charlie how would that Blue Thunder intake work on my combination?
I would think they would work pretty good. The Gateway thing sounds doable. Where's the link to Victory or whatever?
Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  512Fairlane January 26th 2014, 10:08 pm
I had heard they were coming to Gateway this year but I wasn't sure if they let the 385 series engines in. I don't think I would have to change much just cover my aluminum door panels and put some 10.5 W's on it.
http://www.victorynss.com/index.php/victory-nostalgia-superstock-schedule
512Fairlane
512Fairlane
Post  c.evans January 26th 2014, 11:36 pm
So Victory allows the 385 series engine, with 2 X 4 carbs,,,in the old FE chasis Super Stockers. And the have a 10.5 W limit on slick size. Have I got that right?
Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  512Fairlane January 27th 2014, 1:11 am
This is all I found on their site for rules. http://www.victorynss.com/index.php/rules
If you watch the 1st video on their home page http://www.victorynss.com/ they show a white 64 Galaxie at the 2 minute 36 second mark. It has a 460 based motor under the hood with a Blue Thunder intake. I'm assuming this might be dragsterdick's car. Maybe he can chime in for sure but it definitely does not look like an FE motor to me. Before I get serious and buy an intake I would want to call Chris Schnieder to confirm that they would let me run. I also have to see if there is a Gateway points race either of those weekends at those events. It says that the cars can only run one class so that might conflict if I run the Gateway Bracket points again. Hopefully Gateway will post their schedule soon so I can see which dates they have bracket races and decide if it would be worth it to modify my car for NSS.
512Fairlane
512Fairlane
Post  c.evans January 27th 2014, 2:38 am
Let me do some checking on the manifold we've got here, maybe the manifold can be loaned for R&D purposes. Also, I want to get with Paul Kane on those 850 carbs he pictured. Can they use the small float bowls and go in-line?
Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Dual Quads on a 460 - Page 2 Empty Good News and Bad News
Post  512Fairlane January 27th 2014, 10:12 pm
The good news is I spoke with Chris Schnieder tonight and he confirmed that they are allowing the 385 series engines to run in the Fairlanes and Galaxies. The bad news is with my front suspension modifications (rack and pinion and struts) my car would not be allowed. Its understandable that they want to keep the cars looking as original as possible so I know why they have those rules. I raced the car for several years with the stock front suspension and after switching to my new set up there is no way I'm going back. I think they are definitely making the right decision because FE's have gotten way too expensive (imo) to race. Charlie if you ever want someone to test an intake set up in door slammer I'd be up for it but I don't think I'll be able to run with the NSS classes. Sad
512Fairlane
512Fairlane
Dual Quads on a 460 - Page 2 Empty Charlie's Dual Quad Intake
Post  dragsterdick January 27th 2014, 11:19 pm
Heh Charlie, Tell me about the intake and the modifications if you can? I would be interested in trying it as I do run with Victory of course. ( dragsterdick@comcast.net) 630-494-1065 By the way , where are you?
dragsterdick
Post  supervel45 February 12th 2014, 4:45 am
http://www.network54.com/Forum/85220/thread/1120570845/Dyno+test+results+on+460+using+Blue+Thunder+dual+4+barrel+intake+and+tunnel+ram... Adding for the archives, so it does not get lost.
Dual Quads on a 460 - Page 2 Empty If Anyone Needs a Built Set of 4223's
Post  supervel45 May 20th 2016, 1:36 am
Let me Know, I have a Pair coming in that will be ready in a Couple of weeks. They can also be Converted to Progressive Linkage if the Buyer Requests it. One is a 1969 Date Code and the other is a 1970 Model.
Post  supervel45 May 20th 2016, 2:36 am
dfree383 wrote:
kim wrote:get some of them quick fuel 1600 cfm monsters on the thing.  That's 400cfm per runner...  should hold up to anything that did well with a dual plane intake on it.
Probably still on the small side.
So were you Serious?
Post  gt350hr May 20th 2016, 5:55 pm
Yes he is and is one of the few that understand IR set ups need BIG cfm as they do not have a common plenum to draw from. Take the Boss 302 '69 trans am engine which used TWO 1100 cfm dominators or take a look at four Weber carbs. Put either combination on a common plenum manifold and you need 500 ci to take full advantage of the cfm.
A good modification to gain more cfm out of a 660 would be to put down leg booters in the main body. This would up them to around 770 cfm. Ford ( who paid for the development of the center squirter , Dominator , and double pumper) had some hand made ( SK numbered) 780 cfm center squirters made but they are pretty rare.
gt350hr
Post  supervel45 May 20th 2016, 9:21 pm
I know GT, I also Think The Rule Carries Over Somewhat to Dual Plane Dual Quads as they have more plenum volume also, and it came up in another thread on a 521/528 Combo with ported SCJ Heads and a Big Roller Cam. Wink
