best alt bracket set up
best alt bracket set up Empty best alt bracket set up
Post  NOS42 November 3rd 2009, 10:30 pm
just looking for a clean and simple set up that also wont break the bank....some of the March stuff might be ok for some street rodders, but its a little to gawdy for me. I've seen some slick set ups on the small blocks, looking for something the same on a big block
I want to use a 100 amp 1 wire alt, I have a Messier electric water pump....no other belts will be needed.....I will also need a bottom pulley, I would like a alum one if possible....balancer is a Ford motorsport......can anyone point me in the right direction? thanks Mike
NOS42
NOS42
best alt bracket set up Empty Re: best alt bracket set up
Post  NOS42 November 4th 2009, 8:22 am
appears nobody ever purchased a alt bracket set up.....no leads from anyone
how about Pro-Comp? that usually gets the ball rolling!
NOS42
NOS42
Post  maverick November 4th 2009, 9:07 am
Now you've done it! Mad I usually just make that kind of stuff. I'm sure someone will help you out here. Be patient. TTT
Post  jasonf November 4th 2009, 9:29 am
How about something like this that I built for my 289. It is about as low buck as you can get. It just uses the standard bar in the back for tension adjustment. You would not need the idler of course.
best alt bracket set up Customaltbracket
Post  NOS42 November 4th 2009, 10:22 pm
looks pretty simple and neat Jason....I'm just looking for ideas and or places to possibly purchase or build.....even a stock 460 alt only bracket system would be fine....i would set it up, then poweder coat it....again thanks for the pics....Mike
NOS42
NOS42
best alt bracket set up Empty 10 dollars and works great its never tossed a belt
Post  nuclearcobra November 11th 2009, 3:09 pm
best alt bracket set up Th_472pully001 best alt bracket set up Th_IMG_0278
nuclearcobra
nuclearcobra
Post  NOS42 November 11th 2009, 6:30 pm
thank you for posting....really like to look at pics to get some ideas....once again, thanks Mike
NOS42
NOS42
Post  nuclearcobra November 11th 2009, 8:13 pm
As far as the bottem pully go to www.dscmotorsports.com he makes them (Dennis) its a nice piece i bought the other pieces from the hardware store i wanted it simple and light.
nuclearcobra
nuclearcobra
