Low mount alternator bracket and csr water pump
10SHOTS
What are you guys using for a alternator bracket after installing a electric water pump , I seen some aluminum ones on eBay but they don't look like they will work with the ford racing timing pointer , just trying to get some ideas
10SHOTS- Posts : 587
Re: Low mount alternator bracket and csr water pump
Don't know if these will help or not.
http://www.ebay.com/itm/131351570014?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
http://www.ebay.com/itm/121464901775?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
res0rli9- BBF CONTRIBUTOR
bbf-falcon wrote:Made mine
Clev but X2
FalconEh- Posts : 1448
This looks like a job for Keith Fulp
the Coug- Posts : 3055
the Coug wrote:This looks like a job for Keith Fulp
He'll probably wip one out when he reads this.
That would be nice!!res0rli9 wrote:the Coug wrote:This looks like a job for Keith Fulp
I can make one ,but I would rather buy one, the bottom bolt on the aluminum ebay ones hits the ford racing timing pointer , and for anyone they wants to know , ATI timing pointer is basically the same one as the discontinued ford racing
Alt bracket
Would this one work?
http://www-link.com/cgi-bin/odbic.exe/cybercity/scripts/catalog.html?groupname=ford%20parts%20&clientno=1681.0
Kurt.
Kurt.
504T- Posts : 64
10SHOTS wrote:I can make one ,but I would rather buy one, the bottom bolt on the aluminum ebay ones hits the ford racing timing pointer , and for anyone they wants to know , ATI timing pointer is basically the same one as the discontinued ford racing
Do you have a picture of how it hits the timing pointer it may be helpful. Can you modify the bracket or put a spacer behind the pointer?
I'll have to take a pic ,but the timing pointer is in the way of the lower bolt on every aftermarket bracket that I have seen that's used with a electric water pump
If the interference is like a 1/2" spacers under the pointer and longer bolts might work, if not adjustable rods and spherical rod ends can be very helpful, with some careful grinding on spacers or shims for alignment...or crank trigger
» Bracket/s to mount a mech. fuel pump and an alternator
» alternator bracket w/ electric water pump
» alternator mount set up with front engine plate
» who makes a vacum pump setup ,with alternator bracket and hub to work with front plate
» ANYONE RUNNING A RAD OR CHASSIE MOUNT WATER PUMP
