572 questions
572 questions Empty 572 questions
Post  pistol25 January 19th 2014, 9:26 pm
Hi, guys new to this forum. I've always ran lots of small block fords, but am now building a 70 Torino cobra, I bought a 572 short block off a friend at a very good price but now I'm trying to work everything else out. I would like to reuse the cj heads off the car so I keep it looking original I know this will hurt me power wise but for a street car I think I can live with it. my question is what cam should I use? flat tappet? roller? solid roller?etc? and if using the cj heads what about pushrods? stock cj length?
Next question Ive been reading on cometic head gaskets, if I can some 80 thos. thick I can get compression down under 11 to 1 so it can be halfway street able. anybody have any experience with these on street cars?
pistol25
572 questions Empty Re: 572 questions
Post  Larry T January 19th 2014, 9:38 pm
the block and heads surface prep is critical when using the cometic or any multi layered gasket.some will argue that it isn't but that's my real world experience other wise they are good gaskets.
Larry T
Larry T
Post  pistol25 January 19th 2014, 9:44 pm
When you say surface prep of heads and block im assuming you cleaning them?
pistol25
Post  supervel45 January 19th 2014, 9:51 pm
Did you do a compression Calculation, or you estimating a ball park figure with the 11/1 compression number? Do you know the dish CC number of the pistons?
Post  DFI429 January 19th 2014, 10:04 pm
pistol25 wrote:When you say surface prep of heads and block im assuming you cleaning them?
No. Cleaning matters but "surface prep" in this context refers to the machining finish (roughness) of the block deck.
DFI429
DFI429
Post  pistol25 January 19th 2014, 10:42 pm
I haven't done any calculations i'm going by what the guy at the machine shop told me, he is the one who put the bottom end together. He also, redid the cj heads for me. He told me if I don't put 80 thos. head gaskets on it the compression will be over 11 to 1 and recommended the cometic
pistol25
Post  pistol25 January 19th 2014, 10:45 pm
with the surface prep both are fresh from the shop, besides a good cleaning, is there anything else I should be looking for?
pistol25
Post  DFI429 January 19th 2014, 11:38 pm
pistol25 wrote:with the surface prep both are fresh from the shop, besides a good cleaning, is there anything else I should be looking for?
"Fresh from the shop" needs to be the correct "freshness" of sorts..  Read direct from the gasket's mouth:  http://www.cometic.com/technical.aspx
DFI429
DFI429
